TMS phonebook
nicolas.rogers
Hi Cisco User Community,
I am working with TMS 13.x and need to import a .csv file to add to my phonebook. When I search for the file it does not show up.
Is there certain parameters the data needs to be in to allow TMS to accept the file?
The file contains a list of contact data for Vidyo users.
Any help would be appreciated and I'd also be happy to provide more information.
Nick
Vinod Arya
Network management may not be the right community in CSC to answer Telepresence related queries. You may repost or transfer this question to TMS community here :
https://supportforums.cisco.com/community/5886/telepresence
I would get the right attention from the community members and experts.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
5 Replies 5
Vinod Arya
-Thanks
Vinod
Patrick Sparkman
Hello Vinod -
I assume you're using for your TMS phone book source "File Based Phone Book", I've had an issue similar to this in the past where I created a .csv file and it wasn't able to be loaded.  I just created a new Excel document with a single sheet, and saved it as a "CSV (Comma delimtted)" file, and was able to upload it to TMS.  Are you doing the same thing, or something similar?
Hi Patrick,
Yes, I'm doing the same thing using a "File Based Phone Book". Do I need to format the fields in any particular format for TMS to accept it?
Try saving the CSV Excel sheet as a tabbed delimitted text file, that worked for me just now.  It seems TMS doesn't like comma delimitted.
You might try 'exporting' one of your existing phone books and seeing what format that is stored in.  Importing would be the same format.  Also, the location of your 'file based phone book' has to match where you upload the file to import.
