04-25-2013 05:56 AM - edited 03-18-2019 01:00 AM
Hi all
I have just installed TMSPE and switched the TMS provisioning mode over to Provisioning Extensions.
But when I try browse to any of the Provisioning pages in TMS I get a page not found error.
I can’t even get into the Diagnostic Page.
I have tried reinstalling the application and rebooting the server but nothing helps.
I have also tried restarting the TMSAgent Service and TMSProvisioning service with no success.
Any ideas?
I am using TMS 13.2.2 and TMSPE 1.0
04-25-2013 06:42 AM
Hi Haydn, Please remote desktop into TMS and check the tmsagent and TMSPE service status. Is it started ?
Also can you provide screenshot from TMS web --> Administrative Tools --> Configuration -- > General Settings -->
Licenses and Option Keys.
BR, Mahesh Adithiyha
04-25-2013 06:45 AM
Also what is the Java version installed on TMS, java 6 update 33 works fine.
Can you share the errors seen TMSPE installation log.
Checking the installation log:
If problems occur during the installation of Cisco TMSPE to the Cisco TMS server, refer to the Cisco TMSPE Install Log. The Cisco TMSPE Install log can be found in:
C:\Program Files\TANDBERG\TMS\TMSProvisioningExtension\app\logs
This log is also included in the archive of logs provided when going to Administrative Tools > TMS Server Maintenance and clicking Download Log Files.
04-25-2013 07:17 AM
Hi Mahkrish
Thanks for your reply.
I have just uninstalled TMSPE and TMS and am starting from stratch.
Will let you know.
04-29-2013 06:58 AM
Hi Haydn, any update on this ?
04-29-2013 07:49 AM
Hi there.
All is working now.
I reinstalled TMS and TMSPE and all worked.
i think there was an issue with IIS reinstalling TMS rebuilt IIS.
04-29-2013 10:16 AM
Hi Haydn, Thank you for sharing the update.
