TMSXE revert to AD Mode
Bar1s
Unintentionally I chagent to Non Ad mode.
So How I am going to revert do AD mode ? I couldn't find any note in the guides.
R0g22
I believe moving from non-AD to AD is not supported. You will have to reinstall it. I would suggest opening up a TAC case to see if there is a workaround.
Hi Nipun,
I uninstalled TMSXE and reinstalled again. It didn't change anything.
Although I didn't touch the TMS.
I assume we have to remove and completely and installed again ?
fyi.
R0g22
That's why I suggested opening up a TAC case. Also, how did the mode change ? Were you running it in non-AD mode already ? Did you upgrade ?
