10-27-2015 06:49 AM - edited 03-18-2019 05:09 AM
Lately I see more often the need to factory reset the touch 8 as the panel becomes no responsive, any idea how to permanently fix it?
I am running 7.3.2 on a C60 series
10-29-2015 10:18 AM
Is your Touch 8 directly connected or over the network? If it's the latter this might be your problem:
https://tools.cisco.com/bugsearch/bug/CSCum87923
If that the case try directly connecting to the second Ethernet port on the C60 instead of over the network.
10-29-2015 10:35 AM
Thank you Patrick, unfortunately I am not able to direct connect the unit due to floor limitations.
10-29-2015 11:05 AM
If you could try it temporarily, cable on the floor maybe, just to see if it solves the problem you'd at least be able to confirm one way or the other if this is your problem. If it is not I would open a ticket with TAC - you might just have a bad unit.
11-05-2015 06:18 PM
Another thing you can do is to make sure that both the C60 and the Touch are connected to the same Layer 2 network, and preferably the same network switch. This assists greatly with the stability of the two working together.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
