Touch Panel Pairing
Justin Lewis
We currently have Profile C20's with touch panels for control. Is there a way to set the pairing username/password so that it is different from the admin username/password?
2 Accepted Solutions
Dharmesh Nandoria
Hi Leon,
You can create saperate user in codec with admin rights.
User can be created from Maintanance -> User administration .
This you can use for pairing .
kind regards,
Dharmmesh
Hi Leon,
Unfortunately, admin right is required now.   You are right that user will be able to access the advanced configuration of
the codec with the rights.
Dharmesh Nandoria
Hi Leon,
kind regards,
Dharmmesh
Hi Dharmesh,
Thanks for the information. The pairing user account has to have admin rights on the codec? My concern is that should a panel become unpaired and we give an end user the pairing username/password, they could then use that to access the codec from the web with full admin rights.
Hi Leon,
