VIC2-4FXO not working on Cisco 2811
hrnaqvi12
Hi All,
I have installed VIC2-4FXO card on Cisco 2811 at slot 3.
Following is the results of output commands
command "show inventory" reveals
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V01 , SN: FOC103031YV
command "show version" reveals
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK1237F2GX
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
but when I give the command "show voice port summary" nothing is displayed.
I am using the following IOS, "c2800nm-adventerprisek9-mz.124-22.T4.bin".
This is now becoming a show stopper for me. Kindly help me out.
Hasnain Naqvi
Aaron Harrison
What else does 'show inventory' show?
Do you have PVDMs? If not, no voice ports will activate. You will also likely see a message when the router is booting relating to this problem.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Hi Aaron,
Thanks for your post.
I think I am missing PVDMs, but anyhow If PVDMs are missing, why port is not being activated?
"show inventory" complete output is this
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: XXXXXXXXX
Thanks after installation PVDM it worked.
