TRC6 not working on SX20 with 9.2.x?
LuLe
Dear All,
does anyone tested the normal Remote Control with a 9.2.x release on an SX20?
On our systems the Remote Control does not work with 9.2.3 or 9.2.1 - I then put back again the 9.1.4 release and the remote control worked again.
Thank you.
Best regards,
Luise
2 Accepted Solutions
LuLe
Dear All,
we found out that there was the IR setting wrong configured for camera - so issue is fixed.
BR,
Luise
The setting can be found under: Setup > Cameras > IrSensor (On/Off). Must be set to On if the remote control will be used.
LuLe
Dear All,
BR,
Luise
Luise, can you please provide the setting that you had to change, so if someone else finds this thread they can know what is needed to fix restore the remote control IR.
