04-18-2008 08:15 PM - edited 03-17-2019 09:20 PM
We have installed CUVA 2.1.1 software and the VT-II camera installed perfectly fine.CUCM version 6.0 and Presence 6.0.1
Also get the camera Icon on the IP hard phones as well.But unable to place video calls video calls both with CUPC clients and IP hard phones locally on LAN.
Able to launch and see the local and remote image as same on my own system.
Any thing else that I would need to check or missed out any checklist ????
Shams
04-19-2008 04:23 AM
Make sure the device locations have adaquete video bandwidth available.
Ensure the region pairings have a Video BW allocation set per call.
Check IP routing between voice and data VLANs, this is required for camera and phones to communicate.
HTH,
CJ
04-19-2008 07:16 AM
Hi CJ,
Thanks for the info actually the problem is locally I am not able to place video calls.
When I click on the video check option both the local and remote image are the same as the local image.
Please suggest for placing local video calls within a single cluster what all needs to be checked.
Here we are trying to place video calls IP hard phone to IP hard phone,CUPC to CUPC ,
IPC to IPc.
Shams
05-02-2008 12:21 PM
Check your configuration:
callmanager -> device -> phone -> select the right device -> phone configurtion -> product specific configuration layout(last one) -> video capabilities -> set to ENABLE !!!
05-08-2008 09:12 AM
Make sure that Cisco Unified IP Phone is running on the SCCP protocol. Cisco Unified Video Advantage is not supported in a SIP environment.
05-14-2010 07:30 AM
I have same problem with our cupc and hardphones. We cannot make video call. We run on cups 7 and CUPC 7. If you have any idea of that issue, it will be helpful.
regards.
Pamela
05-14-2010 07:39 AM
If you are using desk phone mode, you need to be running CUVA to manage the video. You cannot use the 'video' buttons within the CUPC software.
The buttons within CUPC only work in softphone mode.
Aaron
Please rate helpful posts...
