10-02-2012 08:13 AM - edited 03-17-2019 11:53 PM
I'm planning on upgrading my VCS Control and Expressway from version 6.1 to 7.2.
Do I require an upgrade license for this to work? Also will the different option keys be still installed after the upgrade?
Solved! Go to Solution.
10-02-2012 08:37 AM
Hi Ben,
yes you need a separate software license key for upgrading the 6.1 to 7.2.
you can get the license key by writing to licensing@cisco.com and provide the serial number of the VCS boxes.
Also please note the software you download from cisco site when you do the upgrade. There are two version available encrypted and non-encrypted.
so downlaod the software which you have paid for
Also please follow the vcs upgrade procedure mentioned in the VCS clustering guide as when you take the vcs backup on x6.1 you need to run following commands before you do the backup.
mkdir /tandberg/persistent/oti
mkdir /tandberg/persistent/management
the opiton keys would remain after the upgrade. however please note the same or take screen shot before you go for upgrade.
cheers
Alok
10-02-2012 08:37 AM
Hi Ben,
cheers
Alok
08-27-2014 03:21 PM
We currently have a VCS C and VCS E running 6.1.
We are upgrading to version 7.2, is it required to do any changes to the ASA configuration or something that may affect the current configuration and/ or operation that is just OK?
10-02-2012 09:03 AM
Thank You!
