Upgradeing TMS using TMSPE
Patrick Sparkman
What is the process of upgrading TMS that is currently using TMSPE?  I know with TMS Agent Legacy, you had to diable replication with any VCSs, but I'm not familiar with TMSPE as of yet, and how to upgrade TMS.
2 Accepted Solutions
Magnus Ohm
Just upgrade the tms regulary according to documentation. No need to disable polling.
/Magnus
Martin Koch
The answer: searching in the forum is always a good start :-)
Check out Maheshs answer and Dales repsonse: https://supportforums.cisco.com/message/3688608#3688608
Good success!
Magnus Ohm
/Magnus
Martin Koch
Good success!
