Upgrading Tandberg E20 TE2.1.0 to TE4.1.1. Phone is in both Data & Voice VLANS
stepnharp
I have upgraded a Tandberg E20 TE2.1.0 to TE4.1.1 (no encryption) Phone is now showing up in both Data & Voice/Video VLANS.
It appears that the Data and Voice traffic is being properly handled, due to the fact that when I SHUTDOWN the voice/video VLAN no calls can be sent or received.
Q:  Do I need to worry about why the Tandberg phone is now showing up in both Data & Voice/Video VLANS?
Thanks, Scott
I think what happens is that when the unit boots up, DHCP tries to get IP address in the native VLAN 100. After CDP discovers there's a voice VLAN, the endpoint will request DHCP address on VLAN 11. So you see MAC twice  :
#sh mac address-table
         Mac Address Table
Vlan   Mac Address       Type       Ports
11    0050.6004.2451   DYNAMIC     Gi0/2 // Tandberg E20
100   0050.6004.2451   DYNAMIC     Gi0/2
If you would clear the MAC address table, the entry for 100 will disappear [I hope].
The other entry for the connected PC is normal.
         Mac Address Table
100   1803.73e3.083c   DYNAMIC     Gi0/2 // Workstation connected to E20
We have a ddts where we would not get proper address in case of CDP automatic : CSCtx84402.
Should get fixed in TC6 release.
Danny.
6 Replies 6
Danny De Ridder
the normal process would be to have the video/voice into the VLAN. Data traffic would flow when one has a PC connected to the E20 at the same time.
Can you access the E20 via root and execute some commands ?
ssh to the E20 with admin password and set the root password [here cisco used as example]
[EX90-PDIHD:~] $ tsh
Welcome to EX90_PDIHD
TANDBERG Codec Release TE7.0.0 PreAlpha (TEST SW, te-6.0.0-alpha6-3782-gf93604e)
SW Release Date: 2012-10-02, 15:45, m
OK
systemtools rootsettings on cisco
OK
Then reconnect using root and log the output to a file to capture all the data.
sweet-brew-7:/home/dderidde # ssh root@144.254.12.202
Password:
[EX90-PDIHD:~]
[EX90-PDIHD:~] $ ip add
1: lo: mtu 16436 qdisc noqueue state UNKNOWN
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc htb state UP qlen 1000
    link/ether 00:50:60:04:e8:72 brd ff:ff:ff:ff:ff:ff
    inet 144.254.12.202/25 scope global eth0
    inet6 fe80::250:60ff:fe04:e872/64 scope link
3: eth1: mtu 1500 qdisc pfifo_fast state UP qlen 1000
    link/ether 00:e0:0c:00:8c:02 brd ff:ff:ff:ff:ff:ff
    inet 169.254.0.1/24 brd 169.254.0.255 scope global eth1
    inet6 fe80::2e0:cff:fe00:8c02/64 scope link
4: dummy0: mtu 1500 qdisc noop state DOWN
    link/ether ce:5a:8b:41:21:dd brd ff:ff:ff:ff:ff:ff
5: sit0: mtu 1480 qdisc noop state DOWN
    link/sit 0.0.0.0 brd 0.0.0.0
6: eth1.4090@eth1: mtu 1500 qdisc noqueue state UP
    inet 169.254.1.1/24 brd 169.254.1.255 scope global eth1.4090
[EX90-PDIHD:~] $
[EX90-PDIHD:~] $ cat /var/log/console
Creating tmp files with hw config information
Checking if base file system is mounted... Not mounted.  Mounting...
Mounting base filesystem as yaffs2 from device /dev/mtdblock1
OK.
Mounting /devel... OK.
Mounting /extra... OK.
[EX90-PDIHD:~] $
[EX90-PDIHD:~] $ cat /var/log/messages.log | grep dhclient
Oct  3 05:06:32 (none) dhclient: Bound to *:546
Oct  3 05:06:33 (none) dhclient: RCV: Reply message on eth0 from fe80::21a:30ff:fec8:7800.
Oct  3 05:06:36 (none) dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Oct  3 05:06:36 (none) dhclient: DHCPACK from 144.254.12.130
Oct  3 05:06:37 (none) dhclient: bound to 144.254.12.202 -- renewal in 86504 seconds.
[EX90-PDIHD:~] $
FYI, I will be out of the office until Saturday, I will reply back at that time. Thanks for your time.
Danny,
I have not been able to login as admin or root. The release notes state that no password is set.
Any Suggestion on how to login? I am using BitVise SSH Client 4.5
Thanks for your time, Scott
Alok Jaiswal
Hi Scott,
I don't understand exactly when you say you see endpoint in both the vlans.
however i believe on the switch end you have confiugred the "auxilary" vlan. that is configured the DATA and VOICE/VIDEO vlan voth.
this is for segregating the traffic and the data traffic passing through your E-20 will be via the data vlan.
and hence when you remove the other vlan from the switch or shutdown the voice/video vlan the call stops working.
Cheers
Alok
Alok,
Please see below the E20 is shown in 2 different VLANs.
Native (Data) VLAN = 100
Auxiliary (Voice) VLAN = 11
interface GigabitEthernet0/2
switchport access vlan 100
switchport mode access
switchport voice vlan 11
spanning-tree portfast
         Mac Address Table
         Mac Address Table
         Mac Address Table
Danny.
Danny,
I have done a "clear mac address-table dynamic" on the switch, with the same result as before.
I have installed 8 E20 (TE 4.1.1) on Cisco 3560 switches, all of the phones show up on VLAN 100 and 11.
Having the E20 on VLAN 100 does not seem to cause any problems for the phone or workstation, so I am going to call it good.  Boss likes the new phones, therefore I like it...
Thanks for your effort.
Scott
