Using two Webex Room Navigator on a single Room Kit Pro
BorreTobiassen
HI, I am looking to connectiong two (2) Webex room navigator touch panels to a singel room kit pro.
Reason; table is really long and the customer wants it...
Is this possible?
Can they mirror each other?
Wayne DeNardi
Yes, this is possible.  You will either need to pair the Navigators to the Room Kit Pro over the LAN, or use a small PoE Switch between the Pro's Touch Panel network port and the two Navigators.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
7 Replies 7
I guess that the best option is to try it out. You can at least have multiple Navigators setup for the two different roles that they can have, desk or wall mount, so very likely it should be doable to have two with desk role.
Response Signature
Wayne DeNardi
Wayne
I think that you can connect one to the POE port of the RoomKit and the other via a POE port in the a network switch.
Response Signature
Could I use the same method to connect x2 table navigators on a Plus model?
Yes, you can pair the second one across the LAN. Just make sure in the Plus' Configuration/Peripherals that Remote Pairing is turned on, and TouchPanels is set to 2 or Minimum1.
The Pro actually has two PoE ports, so two Navigators or Touch 10s can be connected directly without a PoE switch or injector.
piotr.sitarz
Is it possible to register 2x Navigators and 1x Navigator as a room reservation when we used Room Bar Pro or Room Kit EQ?
Terminals are registered in CUCM!!
