04-25-2016 09:06 PM - edited 03-18-2019 05:51 AM
I need to integrate Active directory to VCS-C (Expressway C) . I can't find options like Configuration --> Authentication--> Devices --> Active directory services .
I am seeing only Configuration --> Authentication --> outbound connection credentials and local database only .
And in telepresence management suite Provisioning mode is grayed out .Cant able to select options .
Any Idea about this ? I am using Expressway-C x8.5.3 server
Sathish
04-25-2016 11:26 PM
I'm a little confused. In one spot above you are referring to VCS-C, but also to Expressway-C. These are different products and have different capabilities. Can you please confirm exactly what you are using and some more information about your environment and what you are trying to achieve, or which deployment guide you're following?
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-26-2016 01:01 AM
04-26-2016 10:18 AM
Do you have TMSPE installed and enabled on the TMS server?
If you plan on provisioning devices using the VCS, you also need TMSPE licenses installed on TMS.
I recommend you review the TMSPE Deployment Guides to see the requirements and steps to enable TMSPE with your TMS and VCS.
