VCS-C - Issue with point to point calls
novasight
Community Member
We are facing an issue with one of our customers when he try to make a point to point call inside his LAN (between 2 Polycom HDX 7000 codec).
The endpoint A received no audio and no video from the endpoint B
The endpoint B received audio and video from the endpoint A
The gatekeeper is a VCS-C (version X8.2.2)
External calls (outside the LAN) are working well.
Our investigations :
For the endpoint A : the RTP media is routed to the Public IP of our customer
The gatekeeper (VCS-C) send the Public IP of our customer to the endpoint A
The gatekeeper (VCS-C) send the correct IP (private IP) to the endpoint B
When the customer disable the gatekeeper on his endpoints the call is OK
We captured some logs with wireshark, I send it with this case.
Endpoint A is : 10.44.12.69
Endpoint B is : 10.44.12.68
VCS-C is : 10.44.34.20
Public IP is : 80.82.234.187
Could you share the VCS-C Search History for the call from endpoint A ----> B and from endpoint B ----->A.
regards,
Acevirgil
We made 2 test calls with our customer and here is the Search History :
A = 10.44.12.129 = CHU SJ MPR
B = 10.44.12.68 = CHU NANTES SALLE OLERON
