NO NETWORK CONNECTION
Chet Cronin
Level 4
Level 4
Have MXP's running with F8.2 and F9.3.3 on them ...
They register to the gatekeeper.
When dialing out their is a ring and then it drops with error "NO NETWORK CONNECTION" ...
Any Ideas.
I put them in the direct mode and get error code 41 when trying to connect.
I can ping them but for some reason call setup doesn't seem to finish ..
Thanks.
Chet Cronin
Is there a firewall in between these endpoints?
Are you making a local H323 call (both endpoints are registered in same GK)?
Are you using a Cisco VCS as a gatekeeper?
Acevirgil
Yes making h.323 calls ... using the VCS running x8.5.1 ...
These system were working last week ... no one is owning up to any changes :)
We feel it's a network/firewall issue but need to tell them where to look ...
Chet Cronin
