09-20-2013 05:27 PM - edited 03-18-2019 01:50 AM
Hi, as shown below. I'm making SIP call but my VCS-Control is converting that call to H323 before sending it to VCS-Expressway.
how to configure VCS-Control so that it can let H323 calls go as H323 and SIP calls go as SIP calls?
Call summary You are here: Status Calls Calls Call summary
Call Information
State Disconnected
Start time 2013-09-20 11:42:38
End time 2013-09-20 11:48:31
Duration 5 minutes 53 seconds
Bandwidth
Requested 1152 kbps
Allocated 1152 kbps
Route abc -> abcToTraversalSZ -> TraversalSubZone -> Zone002ToTraversalSZ -> Traversal Client
Incoming call:
setup parameters
Source alias 1 sip:1231234@xyz.com (Url)
Target alias 1 sip:john.smith@wxy.net (Url)
Protocol SIP
Address 10.10.10.10:5060
Transport TCP
Encryption type None
Reason OK
Cause 200
Outgoing call:
setup parameters
Source alias 1 1231234@xyz.com (Url)
Target alias 1 john.smith@wxy.net (H323Id)
Protocol H323
Address 192.168.1.1:2776
Cause Normal, unspecified
09-20-2013 05:50 PM
What have you configured in Interworking setting on your VCSC? Can you check if your traversal zone has both protocols actived, SIP and H323?
Paulo Souza
Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
09-20-2013 06:22 PM
Hi Paulo,
H.323 <-> SIP interworking mode - "on" - > will I have to change this mode?
VCS-C traverse zone has both H.323 & SIP protocol active.
09-20-2013 06:32 PM
You should use the interworking mode "Registered only", if you set it "on" you can have undesirable ineterworking behavior on VCS. Try to set it to "Registered only" just to see what you get.
Paulo Souza
09-20-2013 07:40 PM
"Registered only" is the default setting - however, it will still act as H.323<-->SIP gateway since one of the end-points/clients in question is registered with the VCS-C.
The far-end end-point in this case has most probably been registered with the same address for both H.323 and SIP.
In my opinion, to force SIP only for this particular far-end, a neighbouring zone will have to be created on the VCS-E and H.323 turned off in this zone; or, if you want to get even more specific; a neighbouring zone to that specific end-point at that specific far-end site, with H.323 turned off in that zone.
That will allow both H.323 and SIP calls to that far-end, but only SIP calls to that particular far-end end-point.
Heh - I had the exact opposite problem where a far-end had a timer issue with SIP, so I had to force H.323 only.
You could always turn off interworking of course, or turn off H.323 all together, but then what do you do if you want to call a H.323 only site?
If there's no issues with the call when it's interworked then I wouldn't worry too much about it unless there are a specific issue/requirement for having this as SIP only.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
11-10-2017 12:23 PM
How did you force your calls to H323? I’m having the same issue you noted and need calls to go out my expressway over H323
11-11-2017 07:01 PM
09-21-2013 02:01 AM
please check for tranforms also , could be possible of that.
rgds
Alok
09-21-2013 02:13 PM
Also check your search history - see if your VCS-C is sending a SIP search first, getting a "Not found" or something, then trying H323 after the SIP search failed.
