VCS Expressway // - Change Source URI for outgoing call
Hi Experts,
I have VCS Control & VCS Expressway. All the end points are registered to VCS Control.
VCS Expressway version:x7.2.2
Am trying to modify the source-uri for outgoing internet call.
I tried below two cpl configuration. Created the cpl file (.txt) and uploaded to the VCS Expressway and call policy mode is set to Local cpl.
Option 1:
<cpl xsi:schemaLocation="urn:ietf:params:xml:ns:cpl cpl.xsd">
<taa:routed><address-switch field="origin">
<address is="653@xx.local">
<taa:location clear="yes" regex="(.*)" replace="\1" source-url-for-message="653@xx.com">
</taa:location>
</address>
</address-switch>
</taa:routed>
</cpl>
Option 2:
<?xml version="1.0" encoding="UTF-8" ?>
<cpl xmlns="urn:ietf:params:xml:ns:cpl"
xmlns:taa="http://www.tandberg.net/cpl-extensions"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
<taa:routed>
url="653@xx.com"
</taa:location>
</address>
</address-switch>
</taa:routed>
</cpl>
But this did not help me. The exact requirement is  653@xx.local need to change to 653@xx.com while calling. Called party should get CLI as 653@xx.com to call back.
Any help on this is highly appreciated.
Lawrence James
Is this even possible - to change the source address using cpl, transforms or search rules? If this is even possible I would be interested in learning this as well.
FindMe may be able to allow this, but will require some other changes. Do you have the FindMe option?
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-2.pdf). On page 353/4 there is an example that shows you how to do this (I think - however, we have had no cause to do this personally).
Cheers,
Chris
pcusty.mcpc
Hello
and I was interested in your case.   Did you ever find a resolution or a CPL script to work? It is unbelieveable that Cisco do not support such an important feature.
