04-29-2013 01:43 AM - edited 03-18-2019 01:01 AM
I hope someone can just point me in the right direction here.
I have a VCS-E ---- F/W ----- Internet
I can make a succesfull H.323 call to another IP out on the internet.
But when I make a SIP call it fails under the call history it shows as leaving my VCS-E and F/W as SIP and returns as H.323 and gives me the error 480 Temorary Unavailible.
How do I get my VCS-E to send the calls as SIP and receive it back as a SIP call.
My VCS-E has a 1 to 1 NAT to a public IP on the F/W.
What am I doing wrong?
| 2013-04-29 10:15:08 | 2013-04-29 10:15:09 | 1 second | sip:5000@example.com | sip:ny.publicspy.tsec@cisco.com | Traversal | SIP <-> H323 | 480 Temporarily Not Available | This system | View |
Call details
You are here: Status
Calls
Calls
Call details
| Call information | |
| State | Connection Failed |
| Start time | 2013-04-29 10:15:08 |
| End time | 2013-04-29 10:15:09 |
| Duration | 1 second |
| Tag | e7ca80ac-b0a4-11e2-a57a-0010f325e27c |
| Serial number | e7ca7ef4-b0a4-11e2-a0ea-0010f325e27c |
| Bandwidth | |
| Requested | 768 kbps |
| Allocated | 0 kbps |
| Leg 1 | |
| Bandwidth node | Default Subzone |
| Source alias 1 | sip:5000@example.com (Url) |
| Target alias 1 | sip:ny.publicspy.tsec@cisco.com (Url) |
| Protocol | SIP |
| Address | xxx.xxx.xxx.xxx:5061 |
| Transport | TLS |
| Reason | Temporarily Not Available |
| Cause | 480 |
| Leg 2 | |
| Bandwidth node | Cisco |
| Protocol | SIP |
| Address | 64.102.249.41:5061 |
| Transport | TLS |
| Encryption type | None |
| Leg 3 | |
| Target alias 1 | (Unknown) |
| Protocol | SIP |
| Address | Not set |
| Transport | SIP Transport Protocol Undefined |
| Leg 4 | |
| Bandwidth node | DNSZone |
| Protocol | SIP |
| Transport | TLS |
| Leg 5 | |
| Protocol | SIP |
| Address | 64.102.249.41:5060 |
| Transport | TCP |
| Leg 6 | |
| Target alias 1 | ny.publicspy.tsec@cisco.com (Url) |
| Protocol | H323 |
| Address | 64.102.249.41:1720 |
| Reason | Unreachable destination |
| Cause | No route to destination |
| Session 1 | |
| Status | Failed |
| Media routed | False |
| Call routed | True |
| Participant 1 | Leg 1 |
| Participant 2 | Leg 2 |
| Bandwidth allocated | 0 kbps |
| Bandwidth requested | 768 kbps |
| Session 2 | |
| Status | Failed |
| Participant 2 | Leg 4 |
| Bandwidth allocated | 768 kbps |
| Route | DefaultSubZone -> DefaultSZtoDNSZ -> DNSZone |
| Session 3 | |
| Status | Failed |
| Participant 2 | Leg 5 |
| Session 4 | |
| Status | Failed |
| Media routed | True |
| Participant 2 | Leg 6 |
| Bandwidth allocated | 682 kbps |
| Bandwidth requested | 682 kbps |
Search Rule:
04-29-2013 02:19 AM
Hi Janse!
It might be different things here which can cause issues.
First, if you have 1:1 nat upfront the VCS-E you need to have the "Dual interface" option key, even
if you use only one interface, but that option also gives you a setting where you can define the
outside NAT ip on the VCS.
You also need to take care if you are using a NATed interface that all communication is done
towards that external IP, if you require communication with an internal ip or clustering you would need
the secondary interface as well.
There are some more postings regards this topic in the forum, please search for it.
If you do not have the key, thats the first thing to fix as this is a main requirement!
If its in place:
Check that there are no ALG/Inspection/NAT helper or other SIP/H323 Layer3 features enabled
on your firewall, that might lock something up.
I tried the address mysef, and that might be a bad address to check on external sip communication,
it seems that cisco address is only reachable via h323:
|SIP/2.0 404 Not Found
Via: SIP/2.0/TLS xxx;egress-zone=DNS;xxx
Call-ID: xxx@192.168.101.62
CSeq: 100 INVITE
To: <>>ny.publicspy.tsec@cisco.com>;tag=xxx
Server: TANDBERG/4120 (X7.2.1)
Warning: 399 64.103.25.133:5061 "Policy Response"
Content-Length: 0
But at least an interworked call should work from your sip client.
Not sure how your sip settings are, I noticed I did not get encrypted media towards the remote site,
depending on your settings (force encryption) that can also cause issues.
Please rate the postings via the stars below and set the thread to answered if it is!
04-29-2013 03:01 AM
Managed to make the call out using the following URI.
I ahve the dual network card option key everything, it seems like some sort of DNS or SRV record issue maybe for the return path???
sip:ny.publicspy.tsec@64.102.249.41 (Url)
04-29-2013 02:53 PM
Did you factory default the VCS reacently?
Do you have all the needed defautl links?
Logging in as admin via ssh/console and execute:
xcommand DefaultLinksAdd
might be worth giving a try.
Besies that, did you check with the dns lookup tool that your DNS is getting properly resolved?
Also do not forget to check the firewall and your vcs and router nat setup
Janse: Please rate the postings!
04-29-2013 10:49 PM
No Factory reset reacently was configured out of the box.
I have all the dafault links plus the ones I have added.
*r Result (status=OK): /
*r/end
OK
DNS Lookup works if I do it for cisco.com but not for the full URI.
| A | cisco.com. | 10618 | IN | A | 72.163.4.161 |
| AAAA | cisco.com. | 86400 | IN | AAAA | 2001:420:1101:1::a |
| SRV | _h323ls._udp.cisco.com. | 8030 | IN | SRV | 1 0 1719 vcsgw.cisco.com. |
| SRV | _h323cs._tcp.cisco.com. | 86400 | IN | SRV | 1 0 1720 vcsgw.cisco.com. |
| SRV | _sips._tcp.cisco.com. | 8030 | IN | SRV | 1 0 5061 vcsgw.cisco.com. |
| SRV | _sip._tcp.cisco.com. | 8029 | IN | SRV | 1 0 5060 vcsgw.cisco.com. |
On my firewall I see the calls leave as SIP and comes back as H.323 for some reason when dialing the full URI.
But dialing the URI with the @xxx.xxx.xxx.xxx that I get from my call history when trying to resolve the full URI it works like a charm.
I will be moving the VCS-E to a DMZ zone later when the network is upgraded and ready but for testing and demo purposes I need to get it working with a 1:1 NAT using one LAN port on the VCS-E. So when the VCS-E moves to the DMZ I will bring up my VCS-C again as well.
04-30-2013 02:56 AM
Hi Janse,
Have you tried to resolve DNS from VCS-E? if not please check if VCS-E has correct DNS server and is able to resolve SRV records for cisco.com.
Please see the snippet.
Here Request times out, so call is sent out as H323.
Let me know if you have any queries.
Sagar
04-30-2013 06:42 AM
I am moving my VCS-E to a DMZ zone next week with a public IP getting away from the NAT situation, will test next week and give feedback thank you.
12-08-2014 12:15 PM
I really hate to comment on such an old thread...
But I had a similar issue with a similar problem. I found that in my case, this was resolved by using TCP instead of TLS. When I changed my endpoints to use TCP, the ASA inspecting the SIP traffic and offering the NAT conversion for me was able to see the traffic and change the IP's correctly. Calls worked fine after that point.
