VCS Expressway Ports to be opened for VCS Integration
Please let me know which all ports must be opned on firewall for VCS-C and VCS-E Integration and communicaion.
regards,
Manish
Manish,
Usually in Firewall configurations, you trust the traffic that is started from inside going outbound and block the traffic inbound that is not a response.
That is the beuty of the VCS-C and VCS-E configuration.  All connections are started from the VCS-C on the inside of the network, so you do not have to make swiss cheese of the firewall rules.
Hope that this helps.
Martin Koch
Take a look at the documentation, it also depends which services you use on the VCS (sip(s), h323, ...)
if you use tms managtement,  provisioning, ...
Docu:
VCS: http://www.cisco.com/en/US/products/ps11337/tsd_products_support_series_home.html
TMS: http://www.cisco.com/en/US/products/ps11338/tsd_products_support_series_home.html
Especially:
http://www.tandberg.com/support/dl.php?id=1125&dir=Deployment_Guides&fn=Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X4_and_X5.pdf
and the admin guide!
Please vote answers!
