VCS local database
I seem to be having some problems on a new install of TMS, VCS Control and Movi clients.
There is no active directory to integrate with so I need to authenticate to a local database.
I have setup a user there, but when try to register, I am getting a rejection.
The  logs on the VCS seem to be trying to go to a provisioning  server/service on the local VCS(127.0.0.1) but nothing is replying.
I do not see anything in the documentation that tells me I am doing anything incorrectly.
Hints?
Martin Koch
Please always mention which versions you use and more how your deployment looks like.
Do you use the local db or do you try to point the ldap db to 127.0.0.1?
Does your provisioning work without using authentication?
How do your zone authentication settings look like (local subzone where the movi client is located,
default zone, default subzone, ...)
To use movi (incl, using the passwords for the provisioning) you do not need to use the VCS Local DB.
this works just with the provisioning agent.
If you want authentication for registration/calls (and not only the provisioning),
the username passwords you generate in TMS and which are entered in the movi client must
also be added in the local auth DB ( https:///createcredential )
Does the TMS agent diagnostigs show any errors? (especially regarding a sip route)
Martin
