VCS Starter Pack in a datacenter (Behinde fixed NAT)
moemen.mostafa
Hi guys,
We have a Telepresence VCS starter pack express server and it was working great in our office on E2 dataline but now after moving it to a datacenter there is a problem with registering a Movi client to the VCS over the Internet.
The server setup now is this:  VCS Starter pack - Firewall/Touter - Internet - Movi
The VCS is connected to LAN (internal datacenter network with one interface and is static NATed to the Internet with a router)
all ports are open in the firewall (inbound and outbound)
And here is the settings in the VCS:
Default Zone - Authentication Policy - Check Credential
Default Subzone - Authentication Policy - Threat as authenticated
Also here is the log of the Movi Registering attempt from the public network (Internet):
Dec 26 14:11:21
tvcs: Event="Message Sent"   Service="SIP"   Src-ip="10.29.10.43"   Src-port="5061"   Dst-ip="41.130.193.41"   Dst-port="59519"   Protocol="TLS"   Num-bytes="426"   Level="4"   UTCTime="2011-12-26 12:11:21,714"
Dec 26 14:11:21
tvcs: Event="Response Sent"   Service="SIP"   Src-ip="10.29.10.43"   Src-port="5061"   Dst-ip="41.130.193.41"   Dst-port="59519"   Protocol="TLS"   Method="SUBSCRIBE"   To="sip:provisioning@tele.med"   Response-code="404"   Level="3"   UTCTime="2011-12-26   12:11:21,714"
Dec 26 14:11:21
tvcs: Event="Request Received"   Service="SIP"   Src-ip="41.130.193.41"   Src-port="59519"   Dst-ip="10.29.10.43"   Dst-port="5061"   Protocol="TLS"   Method="SUBSCRIBE"   Request-URI="sip:mmostafa@tele.med"   Level="3"   UTCTime="2011-12-26   12:11:21,712"
Dec 26 14:11:21
tvcs: Event="Message Received"   Service="SIP"   Src-ip="41.130.193.41"   Src-port="59519"   Dst-ip="10.29.10.43"   Dst-port="5061"   Protocol="TLS"   Num-bytes="998"   Level="4"   UTCTime="2011-12-26 12:11:21,712"
Dec 26 14:11:21
tvcs: Event="Message Sent"   Service="SIP"   Src-ip="10.29.10.43"   Src-port="5061"   Dst-ip="41.130.193.41"   Dst-port="59519"   Protocol="TLS"   Num-bytes="587"   Level="4"   UTCTime="2011-12-26   12:11:21,643"
Dec 26 14:11:21
tvcs: Event="Response Sent"   Service="SIP"   Src-ip="10.29.10.43"   Src-port="5061"   Dst-ip="41.130.193.41"   Dst-port="59519"   Protocol="TLS"   Method="SUBSCRIBE"   To="sip:provisioning@tele.med"   Response-code="407"   Level="3"   UTCTime="2011-12-26   12:11:21,643"
Dec 26 14:11:21
tvcs: Event="Request Received"   Service="SIP"   Src-ip="41.130.193.41"   Src-port="59519"   Dst-ip="10.29.10.43"   Dst-port="5061"   Protocol="TLS"   Method="SUBSCRIBE"   Request-URI="sip:mmostafa@tele.med"   Level="3"   UTCTime="2011-12-26   12:11:21,642"
Dec 26 14:11:21
tvcs: Event="Message Received"   Service="SIP"   Src-ip="41.130.193.41"   Src-port="59519"   Dst-ip="10.29.10.43"   Dst-port="5061"   Protocol="TLS"   Num-bytes="661"   Level="4"   UTCTime="2011-12-26   12:11:21,642"
Can any one help me in understanding why this happens?
awinter2
Level 7
Level 7
Hi Moemen,
there are multiple threads on this forum which explains the requirements for deploying a VCS in a private DMZ, which you can find by searching for 'VCS Static NAT'.
In short, when deploying the VCS-E in a statically NAT'ed environment, it is required to have the 'Dual network interfaces' option key on the VCS-E, as this key unlocks the static NAT functionality of the VCS-E.
You can also find more information on this in the VCS Administrator's guide for X7.0.
Andreas
awinter2
Level 7
Level 7
Hi Moemen,
Andreas
Thanks Andreas for your prompt answer.
