VCSE need device provisioning key for Movi?
startryst
Hi, Experts
The TMSPE with VCS-Control already worked well, with remote Movi users can login by estalish VPN at first, now I'm working on the VCS-expressway, so that users login Movi without VPN, but just want to check with you that, VCSE required to be managed by TMSPE, so that device provisioning key required for such scenario?
TMS Provisioning Extension services are not available: To use TMS Provisioning Extension services you must install the Device Provisioning and/or FindMe option keys
below is the logging I got when user login, it get back to me not found...but VCSE already joined the AD domain, with DefaultSub zone - Check credentials configured:
2012-11-24T18:47:33+08:00 vcse tvcs: UTCTime="2012-11-24 10:47:33,725" Module="network.sip" Level="INFO":  Dst-ip="61.129.180.69"  Dst-port="52220"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=8f43fc832ba8882d@127.0.0.1"
2012-11-24T18:47:33+08:00 vcse tvcs: UTCTime="2012-11-24 10:47:33,725" Module="network.sip" Level="DEBUG":  Dst-ip="61.129.180.69"  Dst-port="52220"
SIPMSG:
|SIP/2.0 404 Not Found
Via: SIP/2.0/TLS 192.168.1.3:52220;branch=z9hG4bK06563943eb7e8040ae77c19a00baac52.1;received=61.129.180.69;rport=52220;ingress-zone=DefaultZone
Call-ID: 8f43fc832ba8882d@127.0.0.1
CSeq: 201 SUBSCRIBE
From: <sip:shejiang@ewellsoft.com>;tag=096335d9eca2da65
To: <sip:provisioning@ewellsoft.com>;tag=8493d31505b037a3
Server: TANDBERG/4120 (X7.2)
Warning: 399 172.16.5.10:5061 "Policy Response"
Content-Length: 0
15 Replies 15
Tomonori Taniguchi
If you have TMS-PE deployment already with VCS-C and have a traversal link between VCS-E, you don’t need provisioning replication between VCS-E (provisioning key is not required on VCS-E).
By configure conference template properly, you may let Jabber Video client to send subscribe message to VCS-E.
VCS-E will forward such message to VCS-C and VCS-C will handle provisioning request.
Depend on configuration, Jabber Video client may registered on VCS-E or proxy registered on VCS-C.
Configured following parameter on VCS-E;
  • Configure SIP domain for provisioning user to registered on VCS-E
  • Configure Default Zone to “Do not check credential”
  • Configure proxy register to “off”.
Also configure public SIP server address (point to VCS-E) on TMS provisioning template and assign to user account.
Hi, Tomonori
I've set the configuration accroding to your intruction, in addition, I've set the DefaultSubZone to "Do not check credentials", and BTW, the VCSE joined the AD domain which is hosted in the inside of the FW. but still the user can not login, see below for the logging, it still get back to me 404 not found:
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,339" Module="network.tcp" Level="DEBUG":  Src-ip="61.129.183.95" Src-port="49998" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connecting"
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,341" Module="network.tcp" Level="DEBUG":  Src-ip="61.129.183.95" Src-port="49998" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Established"
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,420" Module="network.sip" Level="INFO":  Src-ip="61.129.183.95"  Src-port="49998"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:shejiang@ewellsoft.com, Call-ID=0fe635a4debd1c4b@127.0.0.1"
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,420" Module="network.sip" Level="DEBUG":  Src-ip="61.129.183.95"  Src-port="49998"
SIPMSG:
|SUBSCRIBE sip:shejiang@ewellsoft.com SIP/2.0
Via: SIP/2.0/TLS 192.168.1.3:49998;branch=z9hG4bKa283f3c479b5e9c60a085dc5f23e6971.1;received=61.129.183.95;rport=49998
Call-ID: 0fe635a4debd1c4b@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact:
From: <>shejiang@ewellsoft.com>;tag=223f4b77a7c0efc1
To: <>provisioning@ewellsoft.com>
Max-Forwards: 70
Route: <115.238.97.149:5061>
User-Agent: TANDBERG/774 (MCX 4.5.7.16762) - Mac OS X
Expires: 300
Event: ua-profile;model=movi;vendor=tandberg.com;profile-type=user;version=4.5.7.16762;clientid="7B26CD64-18E7-5443-982A-DD2E496560D2";connectivity=1
Accept: application/pidf+xml
Content-Length: 0
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,424" Module="network.sip" Level="INFO":  Dst-ip="61.129.183.95"  Dst-port="49998"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=0fe635a4debd1c4b@127.0.0.1"
2012-11-25T11:24:58+08:00 vcse tvcs: UTCTime="2012-11-25 03:24:58,424" Module="network.sip" Level="DEBUG":  Dst-ip="61.129.183.95"  Dst-port="49998"
SIPMSG:
Via: SIP/2.0/TLS 192.168.1.3:49998;branch=z9hG4bKa283f3c479b5e9c60a085dc5f23e6971.1;received=61.129.183.95;rport=49998;ingress-zone=DefaultZone
CSeq: 201 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=5534123f177bc444
Content-Length: 0
No need to join VCS-E to AD, take a look at this guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-0.pdf
Authentication, in our case, is handled by the VCS-C (which has been added to AD), regardless of these users being internal or external. Works great.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi, Jens
I've tried VCSc and VCSe joined domain, and Only VCSc joined the domain by below configuration:
And in either way, the system always get back with SIP 404 not found message, and apparetely it passed the authentication, see below for the logging:
VCSc and VCSe both joined AD domain:
2012-11-25T16:23:21+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:21,945" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="22445" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connecting"
2012-11-25T16:23:21+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:21,946" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="22445" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Established"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,172" Module="network.sip" Level="INFO":  Src-ip="64.104.125.217"  Src-port="22445"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:shejiang@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,172" Module="network.sip" Level="DEBUG":  Src-ip="64.104.125.217"  Src-port="22445"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52698;branch=z9hG4bK70b8980aabeb5dce58edb2a46aae7550.1;received=64.104.125.217;rport=22445
Call-ID: 80951456ed5b5915@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact:
From: <>shejiang@ewellsoft.com>;tag=8bfb9a671532e940
Max-Forwards: 70
Expires: 300
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,173" Module="network.sip" Level="INFO":  Dst-ip="64.104.125.217"  Dst-port="22445"   Detail="Sending Response Code=407, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,173" Module="network.sip" Level="DEBUG":  Dst-ip="64.104.125.217"  Dst-port="22445"
SIPMSG:
|SIP/2.0 407 Proxy Authentication Required
CSeq: 201 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=d9c9cb82e3b24176
Proxy-Authenticate: Digest realm="vcse.ewellsoft.com", nonce="b97d0d92882f04831d5402f4fe0915599231db23b0492705d5d5b5aa4147", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", stale=FALSE, algorithm=MD5, qop="auth"
Proxy-Authenticate: NTLM realm="vcse.ewellsoft.com", qop="auth", targetname="vcse.ewellsoft.com"
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,259" Module="network.sip" Level="INFO":  Src-ip="64.104.125.217"  Src-port="22445"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:shejiang@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,259" Module="network.sip" Level="DEBUG":  Src-ip="64.104.125.217"  Src-port="22445"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52698;branch=z9hG4bK69a53960211c5140d63afe7a28196d90.1;received=64.104.125.217;rport=22445
CSeq: 202 SUBSCRIBE
Contact:
Max-Forwards: 70
Expires: 300
Proxy-Authorization: NTLM qop="auth", realm="vcse.ewellsoft.com", targetname="vcse.ewellsoft.com", gssapi-data=""
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,260" Module="network.sip" Level="INFO":  Dst-ip="64.104.125.217"  Dst-port="22445"   Detail="Sending Response Code=407, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,260" Module="network.sip" Level="DEBUG":  Dst-ip="64.104.125.217"  Dst-port="22445"
SIPMSG:
CSeq: 202 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=263c29c47fc07b30
Proxy-Authenticate: NTLM realm="vcse.ewellsoft.com", opaque="051acefb9c1c634c", targetname="vcse.ewellsoft.com", gssapi-data="TlRMTVNTUAACAAAAGgAaADgAAABRgpniTGMcnPvOGgUAAAAAAAAAACIAIgBSAAAAAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAIAGgBFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAAAAAA="
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,345" Module="network.sip" Level="INFO":  Src-ip="64.104.125.217"  Src-port="22445"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:shejiang@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,345" Module="network.sip" Level="DEBUG":  Src-ip="64.104.125.217"  Src-port="22445"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52698;branch=z9hG4bKc9b99722399e6cde9a551747eb7c19f6.1;received=64.104.125.217;rport=22445
CSeq: 203 SUBSCRIBE
Contact:
Max-Forwards: 70
Expires: 300
Proxy-Authorization: NTLM qop="auth", realm="vcse.ewellsoft.com", targetname="vcse.ewellsoft.com", opaque="051acefb9c1c634c", gssapi-data="TlRMTVNTUAADAAAAGAAYAEAAAABSAFIAWAAAABoAGgCqAAAAEAAQAMQAAAASABIA1AAAABAAEADmAAAAVYKYYJlfMRXjQueNFLD5pglPwc86XM70u3mX71IsLs+z5NxzaKURds9NPYUBAQAAAAAAALQG7iHmys0BOlzO9Lt5l+8AAAAAAgAaAEUAVwBFAEwATABTAE8ARgBUAC4AQwBPAE0AAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAHMAaABlAGoAaQBhAG4AZwAxADIANwAuADAALgAwAC4AMQDhMifLmTzQ7OPCPnYnFaiV"
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,345" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication request" client id="4" username="shejiang" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,348" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication succeeded" client id="4" username="shejiang" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM" result="1" reason code="0x0 - No error" reason string=""
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,352" Module="network.sip" Level="INFO":  Dst-ip="64.104.125.217"  Dst-port="22445"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=80951456ed5b5915@127.0.0.1"
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,352" Module="network.sip" Level="DEBUG":  Dst-ip="64.104.125.217"  Dst-port="22445"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52698;branch=z9hG4bKc9b99722399e6cde9a551747eb7c19f6.1;received=64.104.125.217;rport=22445;ingress-zone=DefaultZone
CSeq: 203 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=aa9115ddf5b1ff40
Content-Length: 0
2012-11-25T16:23:22+08:00 vcse tvcs: UTCTime="2012-11-25 08:23:22,435" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="22445" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Closed"
Only VCSc joined the AD domain:
2012-11-25T16:26:18+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:18,771" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="26911" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connecting"
2012-11-25T16:26:18+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:18,773" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="26911" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Established"
2012-11-25T16:26:18+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:18,999" Module="network.sip" Level="INFO":  Src-ip="64.104.125.217"  Src-port="26911"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:shejiang@ewellsoft.com, Call-ID=edbfa16386bb753c@127.0.0.1"
2012-11-25T16:26:18+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:18,999" Module="network.sip" Level="DEBUG":  Src-ip="64.104.125.217"  Src-port="26911"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52701;branch=z9hG4bKc422541ed7bd5c44c85d4359a952cf5c.1;received=64.104.125.217;rport=26911
Call-ID: edbfa16386bb753c@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact:
From: <>shejiang@ewellsoft.com>;tag=e26321c575038f3d
Max-Forwards: 70
Expires: 300
Content-Length: 0
2012-11-25T16:26:19+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:19,003" Module="network.sip" Level="INFO":  Dst-ip="64.104.125.217"  Dst-port="26911"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=edbfa16386bb753c@127.0.0.1"
2012-11-25T16:26:19+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:19,003" Module="network.sip" Level="DEBUG":  Dst-ip="64.104.125.217"  Dst-port="26911"
SIPMSG:
Via: SIP/2.0/TLS 10.125.1.21:52701;branch=z9hG4bKc422541ed7bd5c44c85d4359a952cf5c.1;received=64.104.125.217;rport=26911;ingress-zone=DefaultZone
CSeq: 201 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=5187aeea848cae44
Content-Length: 0
2012-11-25T16:26:19+08:00 vcse tvcs: UTCTime="2012-11-25 08:26:19,088" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="26911" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Closed"
startryst
BTW, below is the configuration template for VCSE provisioned user account, in which the public SIP address is the VCSE's public IP address:
startryst
For AD integration with VCS-E and VCS-C, please refer to page 10 of https://supportforums.cisco.com/docs/DOC-25398 for recommend configuration.
You should configure “Do not check credential” for both Default Zone and Default Subzone on VCS Expressway.
You need to configure “Check credential” for Default Zone for VCS Control.
Also you need to configure either “Check credential” or “Treat as authenticated” for Default Subzone for VCS Control.
Page 11 to 13 for same document, I added expected signal flow on VCS-E, VCS-C and AD server for Jabber Video provisioning.
The log you posted under “Only VCSc joined the AD domain:”, have you removed any logs between “CSeq: 201 SUBSCRIBE” and “|SIP/2.0 404 Not Found”?
If VCS-C properly configure device provisioning and challenging the authentication, I’m expecting see “407 Proxy Authentication” message send back from VCS-C.
Hi, Tomonori
I've set the configuration exactly the same with the page 10 of the link your provided, and I captured debug logs both on VCSe and VCSc, it looks the traversal zone has some problem with it, but I'm not sure what's the problem. Also I've did another logging for user logging by VPN though VCSc, that's successful, appreciate your analysis here for me:
BTW, the status for the TraversalZone is active, all green...
VCSE debug:
start log
2012-11-26T10:16:54+08:00 vcse httpd[17069]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/start_time - changed from: '1353832782' to: '1353896214'" Src-ip="172.17.0.11" Src-port="49983" User="admin" Level="1" UTCTime="2012-11-26 02:16:54"
2012-11-26T10:16:54+08:00 vcse httpd[17069]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '1353832787' to: '0'" Src-ip="172.17.0.11" Src-port="49983" User="admin" Level="1" UTCTime="2012-11-26 02:16:54"
2012-11-26T10:16:54+08:00 vcse httpd[17069]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{}' to: '{'network':'INFO','developer.iwf':'INFO'}'" Src-ip="172.17.0.11" Src-port="49983" User="admin" Level="1" UTCTime="2012-11-26 02:16:54"
2012-11-26T10:16:54+08:00 vcse httpd[17069]: web: Event="System Configuration Changed" Detail="configuration/networklogger/uuid/8d8b4bc8-204c-11e2-9ef1-000c29bc93c9/level - changed from: 'INFO' to: 'DEBUG'" Src-ip="172.17.0.11" Src-port="49983" User="admin" Level="1" UTCTime="2012-11-26 02:16:54"
2012-11-26T10:16:54+08:00 vcse UTCTime="2012-11-26 02:16:54,787" Event="System Configuration Changed" Node="clusterdb@127.0.0.1" Detail="xconfiguration networkLoggerConfiguration uuid 8d8b4bc8-204c-11e2-9ef1-000c29bc93c9 name: network level - changed from: INFO to: DEBUG"
2012-11-26T10:16:54+08:00 vcse tvcs: UTCTime="2012-11-26 02:16:54,835" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7f8cc4760700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:16:54+08:00 vcse b2bua[24976]: UTCTime="2012-11-26 02:16:54,835" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7fd3ee244700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:16:54+08:00 vcse UTCTime="2012-11-26 02:16:54,838" Module="developer.diagnostics.alarmmanager" Level="INFO" CodeLocation="alarmmanager(156)" Detail="Raising alarm" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Parameters="null"
2012-11-26T10:16:54+08:00 vcse management: Level="INFO" Event="Alarm Raised" Id="25019" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Severity="warning" Detail="Verbose log levels configured: One or more modules of the Network Log or Support Log have been set to a level of Debug or Trace" UTCTime="2012-11-26 02:16:54,894"
2012-11-26T10:16:55+08:00 vcse httpd[17069]: web: Event="Diagnostic Logging" Detail="Logging started; DEBUG_MARKER:" UTCTime="2012-11-26 02:16:55"
2012-11-26T10:17:06+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:06,363" Module="network.h323" Level="INFO":  Src-ip="172.16.50.3"  Src-port="1719"
  Detail="Received RAS NST  SeqNum=28107  ASSENT Probe"
2012-11-26T10:17:06+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:06,363" Module="network.h323" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="1719"
Received RAS PDU:
value RasMessage ::= nonStandardMessage :
   requestSeqNum 28107,
   nonStandardData
     nonStandardIdentifier h221NonStandard :
       t35CountryCode 130,
       t35Extension 1,
       manufacturerCode 256
     data '03000004'H
   genericData
       id nonStandard : 'C2F2D2A2152711DDA1230FC456D89593'H,
       parameters
           content raw : '3C7265736F757263657573616765696E666F3E3C74726176657273616C63616C6C7361 ...'H
2012-11-26T10:17:06+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:06,364" Module="network.h323" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="1719"
  Detail="Sending RAS NST  SeqNum=28107  ASSENT Probe"
2012-11-26T10:17:06+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:06,364" Module="network.h323" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="1719"
Sending RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,874" Module="network.sip" Level="INFO":  Src-ip="172.16.50.3"  Src-port="25031"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,875" Module="network.sip" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="25031"
SIPMSG:
|OPTIONS sip:172.16.5.10:7001;transport=tls SIP/2.0
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK86e980f2b7f2270efdcd969580adde7847625;received=172.16.50.3;rport=25031
Call-ID: f0bd8f640c957d3d@172.16.50.3
CSeq: 1948 OPTIONS
To: <172.16.5.10:7001>
Max-Forwards: 0
User-Agent: TANDBERG/4120 (X7.2)
Supported: com.tandberg.vcs.resourceusage
Content-Type: text/xml
Content-Length: 250
25075025000|
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,875" Module="network.sip" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="25031"   Detail="Sending Response Code=401, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,875" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="25031"
SIPMSG:
|SIP/2.0 401 Unauthorised
CSeq: 1948 OPTIONS
To: <172.16.5.10:7001>;tag=535523b5e6e706bb
WWW-Authenticate: Digest realm="TraversalZone", nonce="b1094e9167de4553c31ab177b5ad467c988d87cb9e48898e8586f72302e0", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,878" Module="network.sip" Level="INFO":  Src-ip="172.16.50.3"  Src-port="25031"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,878" Module="network.sip" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="25031"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bKe553d2f5d183da9e7501a238500a4cec47626;received=172.16.50.3;rport=25031
CSeq: 1949 OPTIONS
Max-Forwards: 0
Authorization: Digest nonce="b1094e9167de4553c31ab177b5ad467c988d87cb9e48898e8586f72302e0", realm="TraversalZone", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", algorithm=MD5, uri="sip:172.16.5.10:7001;transport=tls", username="exampleauth", response="2fa39c4fdb064f63ab4d6f6eb00961e3", qop=auth, cnonce="27179510c31f3ecb90786dd4d6eb25a9cc4a867acb764174500c9c52c2c0", nc=00000001
Content-Length: 250
25075025000|
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,878" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:9998/credential/name/exampleauth" Ref="0x7f8cacdbfee0"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,883" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="9998" Dst-ip="127.0.0.1" Dst-port="47297" Response="200 OK" ResponseTime="0.004109" Ref="0x7f8cacdbfee0"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,883" Module="network.ldap" Level="INFO":   Detail="Authentication credential found in directory for identity: exampleauth"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,884" Module="network.sip" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="25031"   Detail="Sending Response Code=200, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:07,884" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="25031"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 1949 OPTIONS
To: <172.16.5.10:7001>;tag=7c4505075ab6f141
Supported: com.tandberg.vcs.resourceusage,path,outbound,gruu
Content-Length: 250
25075025000|
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,633" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="62106" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connecting"
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,634" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="62106" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Established"
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,867" Module="network.sip" Level="INFO":  Src-ip="64.104.125.217"  Src-port="62106"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=43ec19e31a7fab4f@127.0.0.1"
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,867" Module="network.sip" Level="DEBUG":  Src-ip="64.104.125.217"  Src-port="62106"
SIPMSG:
|SUBSCRIBE sip:lianzhao@ewellsoft.com SIP/2.0
Via: SIP/2.0/TLS 10.140.21.37:50010;branch=z9hG4bK2821e936de714c5399ca8b9fbd1de93d.1;received=64.104.125.217;rport=62106
Call-ID: 43ec19e31a7fab4f@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact:
From: <>lianzhao@ewellsoft.com>;tag=9d217a235225f510
Max-Forwards: 70
Expires: 300
Event: ua-profile;model=movi;vendor=tandberg.com;profile-type=user;version=4.5.7.16762;clientid="F87E357E-8D2E-4DBE-A7BE-ADAE714D8E6B";connectivity=1
Content-Length: 0
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,872" Module="network.sip" Level="INFO":  Dst-ip="64.104.125.217"  Dst-port="62106"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=43ec19e31a7fab4f@127.0.0.1"
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,872" Module="network.sip" Level="DEBUG":  Dst-ip="64.104.125.217"  Dst-port="62106"
SIPMSG:
Via: SIP/2.0/TLS 10.140.21.37:50010;branch=z9hG4bK2821e936de714c5399ca8b9fbd1de93d.1;received=64.104.125.217;rport=62106;ingress-zone=DefaultZone
CSeq: 201 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=8a451e62bccb9167
Content-Length: 0
2012-11-26T10:17:10+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:10,951" Module="network.tcp" Level="DEBUG":  Src-ip="64.104.125.217" Src-port="62106" Dst-ip="172.16.5.10" Dst-port="5061" Detail="TCP Connection Closed"
2012-11-26T10:17:26+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:26,364" Module="network.h323" Level="INFO":  Src-ip="172.16.50.3"  Src-port="1719"
  Detail="Received RAS NST  SeqNum=28108  ASSENT Probe"
2012-11-26T10:17:26+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:26,364" Module="network.h323" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="1719"
Received RAS PDU:
   requestSeqNum 28108,
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:26+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:26,364" Module="network.h323" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="1719"
  Detail="Sending RAS NST  SeqNum=28108  ASSENT Probe"
2012-11-26T10:17:26+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:26,364" Module="network.h323" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="1719"
Sending RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,874" Module="network.sip" Level="INFO":  Src-ip="172.16.50.3"  Src-port="25031"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,874" Module="network.sip" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="25031"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bKfc4abdb19cde56fe03129c08064f259347627;received=172.16.50.3;rport=25031
Call-ID: 4bc54fc13d18f621@172.16.50.3
CSeq: 15563 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,875" Module="network.sip" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="25031"   Detail="Sending Response Code=401, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,875" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="25031"
SIPMSG:
CSeq: 15563 OPTIONS
To: <172.16.5.10:7001>;tag=36dbdc71e683d9b6
WWW-Authenticate: Digest realm="TraversalZone", nonce="da7f84449b17dd6c800ab6f108c134b07f1a64c7f661e64542a93116a769", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,878" Module="network.sip" Level="INFO":  Src-ip="172.16.50.3"  Src-port="25031"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,878" Module="network.sip" Level="DEBUG":  Src-ip="172.16.50.3"  Src-port="25031"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK52e68a2fa7abae6cbbd452bbbd8817e647628;received=172.16.50.3;rport=25031
CSeq: 15564 OPTIONS
Max-Forwards: 0
Authorization: Digest nonce="da7f84449b17dd6c800ab6f108c134b07f1a64c7f661e64542a93116a769", realm="TraversalZone", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", algorithm=MD5, uri="sip:172.16.5.10:7001;transport=tls", username="exampleauth", response="f814c7e8ccba187aa4f1e3f3cc629d05", qop=auth, cnonce="368176390f379ae4c308a4dce4f75f83ce0ea7e530c80866bcc1c211853e", nc=00000001
Content-Length: 250
25075025000|
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,879" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:9998/credential/name/exampleauth" Ref="0x7f8cacdbfee0"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,883" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="9998" Dst-ip="127.0.0.1" Dst-port="47297" Response="200 OK" ResponseTime="0.003857" Ref="0x7f8cacdbfee0"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,883" Module="network.ldap" Level="INFO":   Detail="Authentication credential found in directory for identity: exampleauth"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,884" Module="network.sip" Level="INFO":  Dst-ip="172.16.50.3"  Dst-port="25031"   Detail="Sending Response Code=200, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcse tvcs: UTCTime="2012-11-26 02:17:27,884" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.50.3"  Dst-port="25031"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 15564 OPTIONS
To: <172.16.5.10:7001>;tag=26cc42480d984b7f
Content-Length: 250
25075025000|
2012-11-26T10:17:39+08:00 vcse httpd[15664]: web: Event="Diagnostic Logging" Detail="Logging stopped; DEBUG_MARKER:" UTCTime="2012-11-26 02:17:39"
2012-11-26T10:17:39+08:00 vcse httpd[15664]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '0' to: '1353896259'" Src-ip="172.17.0.11" Src-port="50041" User="admin" Level="1" UTCTime="2012-11-26 02:17:39"
2012-11-26T10:17:39+08:00 vcse httpd[15664]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{'network':'INFO','developer.iwf':'INFO'}' to: '{}'" Src-ip="172.17.0.11" Src-port="50041" User="admin" Level="1" UTCTime="2012-11-26 02:17:39"
stop log
VCSC Debug:
start log
2012-11-26T10:16:51+08:00 vcsc httpd[28663]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/start_time - changed from: '1353674412' to: '1353896211'" Src-ip="172.17.0.11" Src-port="49984" User="admin" Level="1" UTCTime="2012-11-26 02:16:51"
2012-11-26T10:16:51+08:00 vcsc httpd[28663]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '1353674420' to: '0'" Src-ip="172.17.0.11" Src-port="49984" User="admin" Level="1" UTCTime="2012-11-26 02:16:51"
2012-11-26T10:16:51+08:00 vcsc httpd[28663]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{}' to: '{'network':'INFO','developer.iwf':'INFO'}'" Src-ip="172.17.0.11" Src-port="49984" User="admin" Level="1" UTCTime="2012-11-26 02:16:51"
2012-11-26T10:16:51+08:00 vcsc UTCTime="2012-11-26 02:16:51,739" Event="System Configuration Changed" Node="clusterdb@127.0.0.1" Detail="xconfiguration networkLoggerConfiguration uuid b7296014-1f57-11e2-a0cf-000c29f3450f name: network level - changed from: INFO to: DEBUG"
2012-11-26T10:16:51+08:00 vcsc httpd[28663]: web: Event="System Configuration Changed" Detail="configuration/networklogger/uuid/b7296014-1f57-11e2-a0cf-000c29f3450f/level - changed from: 'INFO' to: 'DEBUG'" Src-ip="172.17.0.11" Src-port="49984" User="admin" Level="1" UTCTime="2012-11-26 02:16:51"
2012-11-26T10:16:51+08:00 vcsc tvcs: UTCTime="2012-11-26 02:16:51,818" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7f7ba94d1700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:16:51+08:00 vcsc b2bua[29807]: UTCTime="2012-11-26 02:16:51,818" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7fb57fae3700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:16:51+08:00 vcsc UTCTime="2012-11-26 02:16:51,821" Module="developer.diagnostics.alarmmanager" Level="INFO" CodeLocation="alarmmanager(156)" Detail="Raising alarm" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Parameters="null"
2012-11-26T10:16:51+08:00 vcsc management: Level="INFO" Event="Alarm Raised" Id="25019" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Severity="warning" Detail="Verbose log levels configured: One or more modules of the Network Log or Support Log have been set to a level of Debug or Trace" UTCTime="2012-11-26 02:16:51,848"
2012-11-26T10:16:52+08:00 vcsc httpd[28663]: web: Event="Diagnostic Logging" Detail="Logging started; DEBUG_MARKER:" UTCTime="2012-11-26 02:16:52"
2012-11-26T10:17:06+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:06,371" Module="network.h323" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="6001"
2012-11-26T10:17:06+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:06,372" Module="network.h323" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="6001"
Sending RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:06+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:06,373" Module="network.h323" Level="INFO":  Src-ip="172.16.5.10"  Src-port="6001"
2012-11-26T10:17:06+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:06,374" Module="network.h323" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="6001"
Received RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:07+08:00 vcsc UTCTime="2012-11-26 02:17:07,624" Module="developer.externalmanager.processor.devicerepository" Level="INFO" CodeLocation="devicerepositoryprocessor(84)" Service="devicerepository" Detail="Synchronizing licences table."
2012-11-26T10:17:07+08:00 vcsc provisioning: Level="INFO" Service="devicerepository" Detail="Polled TMS Provisioning Extension Services : processed incoming data" UpdateOrAddOperations="1" DeleteOperations="0" FullSynchronization="no" UTCTime="2012-11-26 02:17:07,639"
2012-11-26T10:17:07+08:00 vcsc UTCTime="2012-11-26 02:17:07,641" Module="developer.externalmanager.importer" Level="INFO" CodeLocation="importcontrol(381)" Detail="Import successful" Service="device"
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,882" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,882" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK86e980f2b7f2270efdcd969580adde7847625;rport
CSeq: 1948 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,885" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=401, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,885" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
CSeq: 1948 OPTIONS
Content-Length: 0
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,886" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,886" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bKe553d2f5d183da9e7501a238500a4cec47626;rport
CSeq: 1949 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,894" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=200, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=f0bd8f640c957d3d@172.16.50.3"
2012-11-26T10:17:07+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:07,894" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 1949 OPTIONS
Content-Length: 250
25075025000|
2012-11-26T10:17:21+08:00 vcsc UTCTime="2012-11-26 02:17:21,648" Module="developer.externalmanager.processor" Level="INFO" CodeLocation="processor(317)" Service="userpreference" Detail="Polling for updates from external manager (current revisions: [u'13b1dbe7985-47', u'13b1dbe7985-47', u'13b1dbe7985-47'])"
2012-11-26T10:17:21+08:00 vcsc UTCTime="2012-11-26 02:17:21,757" Module="developer.externalmanager.processor" Level="INFO" CodeLocation="processor(303)" Service="userpreference" Detail="Importing all entries." FromUrl="/template_schemas" DeleteBeforeImporting="False"
2012-11-26T10:17:21+08:00 vcsc provisioning: Level="INFO" Service="userpreference" Detail="Polled TMS Provisioning Extension Services : no incoming data to process" UTCTime="2012-11-26 02:17:21,778"
2012-11-26T10:17:21+08:00 vcsc UTCTime="2012-11-26 02:17:21,782" Module="developer.externalmanager.importer" Level="INFO" CodeLocation="importcontrol(381)" Detail="Import successful" Service="userpreference"
2012-11-26T10:17:26+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:26,371" Module="network.h323" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="6001"
2012-11-26T10:17:26+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:26,372" Module="network.h323" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="6001"
Sending RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:26+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:26,374" Module="network.h323" Level="INFO":  Src-ip="172.16.5.10"  Src-port="6001"
2012-11-26T10:17:26+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:26,374" Module="network.h323" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="6001"
Received RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,882" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,882" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bKfc4abdb19cde56fe03129c08064f259347627;rport
CSeq: 15563 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,885" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=401, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,885" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
CSeq: 15563 OPTIONS
Content-Length: 0
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,886" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,886" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK52e68a2fa7abae6cbbd452bbbd8817e647628;rport
CSeq: 15564 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,894" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=200, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=4bc54fc13d18f621@172.16.50.3"
2012-11-26T10:17:27+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:27,894" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 15564 OPTIONS
Content-Length: 250
25075025000|
2012-11-26T10:17:37+08:00 vcsc UTCTime="2012-11-26 02:17:37,795" Module="developer.externalmanager.processor.devicerepository" Level="INFO" CodeLocation="devicerepositoryprocessor(84)" Service="devicerepository" Detail="Synchronizing licences table."
2012-11-26T10:17:37+08:00 vcsc provisioning: Level="INFO" Service="devicerepository" Detail="Polled TMS Provisioning Extension Services : processed incoming data" UpdateOrAddOperations="1" DeleteOperations="0" FullSynchronization="no" UTCTime="2012-11-26 02:17:37,815"
2012-11-26T10:17:37+08:00 vcsc UTCTime="2012-11-26 02:17:37,819" Module="developer.externalmanager.importer" Level="INFO" CodeLocation="importcontrol(381)" Detail="Import successful" Service="device"
2012-11-26T10:17:46+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:46,372" Module="network.h323" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="6001"
  Detail="Sending RAS NST  SeqNum=28109  ASSENT Probe"
2012-11-26T10:17:46+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:46,372" Module="network.h323" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="6001"
Sending RAS PDU:
   requestSeqNum 28109,
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:46+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:46,374" Module="network.h323" Level="INFO":  Src-ip="172.16.5.10"  Src-port="6001"
  Detail="Received RAS NST  SeqNum=28109  ASSENT Probe"
2012-11-26T10:17:46+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:46,374" Module="network.h323" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="6001"
Received RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,882" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=609b0c8c1a95335a@172.16.50.3"
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,882" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK8ee9905bd0fac8f3308b6a564f39151347629;rport
Call-ID: 609b0c8c1a95335a@172.16.50.3
CSeq: 25470 OPTIONS
Max-Forwards: 0
Content-Length: 250
25075025000|
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,884" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=401, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=609b0c8c1a95335a@172.16.50.3"
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,885" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK8ee9905bd0fac8f3308b6a564f39151347629;received=172.16.50.3;rport=25031
CSeq: 25470 OPTIONS
To: <172.16.5.10:7001>;tag=87d33029ae80852e
WWW-Authenticate: Digest realm="TraversalZone", nonce="564c0703fbaf5ce0a18cddd5e8854aaed6756da11542dffff4c24866bce0", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,885" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=OPTIONS, Request-URI=sip:172.16.5.10:7001;transport=tls, Call-ID=609b0c8c1a95335a@172.16.50.3"
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,886" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK92b2b2cf5861f15eb77f3aa7bf8aba3747630;rport
CSeq: 25471 OPTIONS
Max-Forwards: 0
Authorization: Digest nonce="564c0703fbaf5ce0a18cddd5e8854aaed6756da11542dffff4c24866bce0", realm="TraversalZone", opaque="AQAAAFpYNeWCOH2arRyzlJ1aAW6oo4Kn", algorithm=MD5, uri="sip:172.16.5.10:7001;transport=tls", username="exampleauth", response="496556713dc2a4aee504df28448c8293", qop=auth, cnonce="fe16d5737df920e4e265b131b1f4855fb5bd19334900f628059d29ed2dfa", nc=00000001
Content-Length: 250
25075025000|
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,892" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=200, Method=OPTIONS, To=sip:172.16.5.10:7001, Call-ID=609b0c8c1a95335a@172.16.50.3"
2012-11-26T10:17:47+08:00 vcsc tvcs: UTCTime="2012-11-26 02:17:47,893" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
|SIP/2.0 200 OK
Via: SIP/2.0/TLS 172.16.50.3:5061;branch=z9hG4bK92b2b2cf5861f15eb77f3aa7bf8aba3747630;received=172.16.50.3;rport=25031
CSeq: 25471 OPTIONS
To: <172.16.5.10:7001>;tag=4d97fdb10de942ed
Content-Length: 250
25075025000|
2012-11-26T10:17:49+08:00 vcsc UTCTime="2012-11-26 02:17:49,248" Module="developer.phpsessionmonitor" Level="INFO" CodeLocation="sessionmonitor(161)" Detail="Web session closed, clearing from utmp"
2012-11-26T10:17:52+08:00 vcsc taa-chkpasswd: Event="pam" Module="pam_unix(taa-chkpasswd-webadmin:session)" Level="INFO"  Detail="session opened for user admin by (uid=2)" UTCTime="2012-11-26 02:17:52"
2012-11-26T10:17:52+08:00 vcsc httpd[29019]: web: User="admin" Event="Admin Session Start" Src-ip="172.17.0.11" Src-port="50049" UTCTime="2012-11-26 02:17:52"
2012-11-26T10:17:52+08:00 vcsc UTCTime="2012-11-26 02:17:52,298" Module="developer.phpsessionmonitor" Level="INFO" CodeLocation="sessionmonitor(171)" Detail="Web session created" client="172.17.0.11:50049"
2012-11-26T10:17:57+08:00 vcsc httpd[29019]: web: Event="Diagnostic Logging" Detail="Logging stopped; DEBUG_MARKER:" UTCTime="2012-11-26 02:17:57"
2012-11-26T10:17:57+08:00 vcsc httpd[29019]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '0' to: '1353896277'" Src-ip="172.17.0.11" Src-port="50049" User="admin" Level="1" UTCTime="2012-11-26 02:17:57"
2012-11-26T10:17:57+08:00 vcsc httpd[29019]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{'network':'INFO','developer.iwf':'INFO'}' to: '{}'" Src-ip="172.17.0.11" Src-port="50049" User="admin" Level="1" UTCTime="2012-11-26 02:17:57"
2012-11-26T10:17:57+08:00 vcsc httpd[29019]: web: Event="System Configuration Changed" Detail="configuration/networklogger/uuid/b7296014-1f57-11e2-a0cf-000c29f3450f/level - changed from: 'DEBUG' to: 'INFO'" Src-ip="172.17.0.11" Src-port="50049" User="admin" Level="1" UTCTime="2012-11-26 02:17:57"
stop log
VCSC debug for jabber video login though VPN(successful):
start log
2012-11-26T10:26:13+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/start_time - changed from: '1353896211' to: '1353896773'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:13"
2012-11-26T10:26:13+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '1353896277' to: '0'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:13"
2012-11-26T10:26:13+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{}' to: '{'network':'INFO','developer.iwf':'INFO'}'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:13"
2012-11-26T10:26:13+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/networklogger/uuid/b7296014-1f57-11e2-a0cf-000c29f3450f/level - changed from: 'INFO' to: 'DEBUG'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:13"
2012-11-26T10:26:13+08:00 vcsc UTCTime="2012-11-26 02:26:13,605" Event="System Configuration Changed" Node="clusterdb@127.0.0.1" Detail="xconfiguration networkLoggerConfiguration uuid b7296014-1f57-11e2-a0cf-000c29f3450f name: network level - changed from: INFO to: DEBUG"
2012-11-26T10:26:13+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:13,658" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7f7ba94d1700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:26:13+08:00 vcsc b2bua[29807]: UTCTime="2012-11-26 02:26:13,658" Module="developer.ttlog.monitor" Level="INFO" CodeLocation="allshare/ttlog/ttlog_control.cpp(629)" Method="ttlog::ttlog_control::TTLogConfigFileMonitor::changeDetected" Thread="0x7fb57fae3700":  Config-File="ttlog.conf" Detail="Reconfiguring ttlog subsystem due to configuration file update"
2012-11-26T10:26:13+08:00 vcsc UTCTime="2012-11-26 02:26:13,661" Module="developer.diagnostics.alarmmanager" Level="INFO" CodeLocation="alarmmanager(156)" Detail="Raising alarm" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Parameters="null"
2012-11-26T10:26:13+08:00 vcsc management: Level="INFO" Event="Alarm Raised" Id="25019" UUID="38c9ca26-fd25-4bac-b5e7-83b1052fd131" Severity="warning" Detail="Verbose log levels configured: One or more modules of the Network Log or Support Log have been set to a level of Debug or Trace" UTCTime="2012-11-26 02:26:13,708"
2012-11-26T10:26:14+08:00 vcsc httpd[7079]: web: Event="Diagnostic Logging" Detail="Logging started; DEBUG_MARKER:" UTCTime="2012-11-26 02:26:14"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,299" Module="network.tcp" Level="DEBUG":  Src-ip="172.17.0.11" Src-port="50159" Dst-ip="172.16.50.3" Dst-port="5061" Detail="TCP Connecting"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,300" Module="network.tcp" Level="DEBUG":  Src-ip="172.17.0.11" Src-port="50159" Dst-ip="172.16.50.3" Dst-port="5061" Detail="TCP Connection Established"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,513" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50159"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,514" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50159"
SIPMSG:
Via: SIP/2.0/TLS 172.17.0.11:50159;branch=z9hG4bK427bbb10feb3b96664e8099c8a3062ba.1;received=172.17.0.11;rport=50159
Call-ID: cea47db95f15840d@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact:
From: <>lianzhao@ewellsoft.com>;tag=12a08f2316f7ccf0
Max-Forwards: 70
Route: <172.16.50.3:5061>
Expires: 300
Event: ua-profile;model=movi;vendor=tandberg.com;profile-type=user;version=4.5.7.16762;clientid="F87E357E-8D2E-4DBE-A7BE-ADAE714D8E6B";connectivity=0
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,514" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50159"   Detail="Sending Response Code=407, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,514" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50159"
SIPMSG:
CSeq: 201 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=59af1e38672d93ce
Proxy-Authenticate: Digest realm="vcsc.ewellsoft.com", nonce="4e91a0705e93d30ae0880f68142288340b7ce8a5831f17569abc6f82f47c", opaque="AQAAACi1nkiZ68/UThGK5ErNz7Q52Z1G", stale=FALSE, algorithm=MD5, qop="auth"
Proxy-Authenticate: NTLM realm="vcsc.ewellsoft.com", qop="auth", targetname="vcsc.ewellsoft.com"
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,594" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50159"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,594" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50159"
SIPMSG:
Via: SIP/2.0/TLS 172.17.0.11:50159;branch=z9hG4bKf3cff195b1d7de6be882d4879d31dab8.1;received=172.17.0.11;rport=50159
CSeq: 202 SUBSCRIBE
Contact:
Max-Forwards: 70
Expires: 300
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", gssapi-data=""
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,595" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50159"   Detail="Sending Response Code=407, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,595" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50159"
SIPMSG:
CSeq: 202 SUBSCRIBE
To: <>provisioning@ewellsoft.com>;tag=be48c90d5bf5504f
Proxy-Authenticate: NTLM realm="vcsc.ewellsoft.com", opaque="576d80df62399f7e", targetname="vcsc.ewellsoft.com", gssapi-data="TlRMTVNTUAACAAAAGgAaADgAAABRgpnifp85Yt+AbVcAAAAAAAAAACIAIgBSAAAAAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAIAGgBFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAAAAAA="
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,674" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50159"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,674" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50159"
SIPMSG:
Via: SIP/2.0/TLS 172.17.0.11:50159;branch=z9hG4bK291dc6af384cd97e2c86273007e17fff.1;received=172.17.0.11;rport=50159
CSeq: 203 SUBSCRIBE
Contact:
Max-Forwards: 70
Expires: 300
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="576d80df62399f7e", gssapi-data="TlRMTVNTUAADAAAAGAAYAEAAAABSAFIAWAAAABoAGgCqAAAAEAAQAMQAAAASABIA1AAAABAAEADmAAAAVYKYYPbEz6zy2/6AYVlVRxftEI5OJdss6oRHECy+49eGJ9ND3BzXQWgru+ABAQAAAAAAAKyeyGp9y80BTiXbLOqERxAAAAAAAgAaAEUAVwBFAEwATABTAE8ARgBUAC4AQwBPAE0AAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAGwAaQBhAG4AegBoAGEAbwAxADIANwAuADAALgAwAC4AMQB/rPpJUlwSG8ZW2NaIc5Gz"
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,675" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication request" client id="58" username="lianzhao" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,678" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication succeeded" client id="58" username="lianzhao" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM" result="1" reason code="0x0 - No error" reason string=""
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,682" Module="network.sip" Level="INFO":  Dst-ip="127.0.0.1"  Dst-port="22410"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,682" Module="network.sip" Level="DEBUG":  Dst-ip="127.0.0.1"  Dst-port="22410"
SIPMSG:
Via: SIP/2.0/UDP 127.0.0.1:5060;egress-zone=DefaultZone;branch=z9hG4bK20b6b6a4dc9b6c373b0bb911b3360f6f47681.35f83c3835974b4a2f4d51b39e1cc3ca;proxy-call-id=a90fda7c-3770-11e2-9291-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50159;branch=z9hG4bK291dc6af384cd97e2c86273007e17fff.1;received=172.17.0.11;rport=50159;ingress-zone=DefaultZone
CSeq: 203 SUBSCRIBE
Contact:
Max-Forwards: 69
Record-Route: <127.0.0.1:5060>
Record-Route: <172.16.50.3:5061>
Expires: 300
P-Asserted-Identity: <>lianzhao@ewellsoft.com>
X-TAATag: a90fdd6a-3770-11e2-b52a-000c29f3450f
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,690" Module="network.sip" Level="INFO":  Src-ip="127.0.0.1"  Src-port="22410"   Detail="Receive Response Code=200, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,690" Module="network.sip" Level="DEBUG":  Src-ip="127.0.0.1"  Src-port="22410"
SIPMSG:
|SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK20b6b6a4dc9b6c373b0bb911b3360f6f47681.35f83c3835974b4a2f4d51b39e1cc3ca;received=127.0.0.1;rport=5060;egress-zone=DefaultZone;proxy-call-id=a90fda7c-3770-11e2-9291-000c29f3450f
CSeq: 203 SUBSCRIBE
Contact: "VCS Provisioning Service" <127.0.0.1:22410>
To: <>provisioning@ewellsoft.com>;tag=185f7927a0db1b7f
Expires: 300
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,691" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50159"   Detail="Sending Response Code=200, Method=SUBSCRIBE, To=sip:provisioning@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,691" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50159"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 203 SUBSCRIBE
Expires: 300
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc provisioning: Level="INFO" Detail="Provisioned user" User-URI="lianzhao@ewellsoft.com" AOR="lianzhao@ewellsoft.com" SIP-Proxy="172.16.50.3" UTCTime="2012-11-26 02:26:18,695"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,698" Module="network.sip" Level="INFO":  Src-ip="127.0.0.1"  Src-port="22410"   Detail="Receive Request Method=NOTIFY, Request-URI=sip:lianzhao@172.17.0.11:50159;transport=tls, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,699" Module="network.sip" Level="DEBUG":  Src-ip="127.0.0.1"  Src-port="22410"
SIPMSG:
|NOTIFY sip:lianzhao@172.17.0.11:50159;transport=tls SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:22410;received=127.0.0.1
CSeq: 126 NOTIFY
From: <>provisioning@ewellsoft.com>;tag=185f7927a0db1b7f
To: <>lianzhao@ewellsoft.com>;tag=12a08f2316f7ccf0
Max-Forwards: 70
P-Asserted-Identity: <>provisioning@ewellsoft.com>
Subscription-State: active
Content-Length: 438
http://www.tandberg.net/Provisioning/2/">phonebook@ewellsoft.com172.16.50.3lianzhao@ewellsoft.compresence@ewellsoft.comZhao Bright|
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,702" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50159"   Detail="Sending Request Method=NOTIFY, Request-URI=sip:lianzhao@172.17.0.11:50159;transport=tls, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,702" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50159"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=DefaultZone;branch=z9hG4bK0a9f5458c95588db7b352695b825435847682.22d3ef2679ed2b9f6f0849f7dd7925bd;proxy-call-id=a9130134-3770-11e2-8732-000c29f3450f;rport
Via: SIP/2.0/UDP 127.0.0.1:22410;received=127.0.0.1;ingress-zone=DefaultZone
CSeq: 126 NOTIFY
Max-Forwards: 69
X-TAATag: a9130378-3770-11e2-830b-000c29f3450f
Content-Length: 438
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,847" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50159"   Detail="Receive Response Code=200, Method=NOTIFY, To=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,847" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50159"
SIPMSG:
|SIP/2.0 200 OK
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=DefaultZone;branch=z9hG4bK0a9f5458c95588db7b352695b825435847682.22d3ef2679ed2b9f6f0849f7dd7925bd;proxy-call-id=a9130134-3770-11e2-8732-000c29f3450f;received=172.16.50.3;rport=5061
CSeq: 126 NOTIFY
Server: TANDBERG/774 (MCX 4.5.7.16762)
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="576d80df62399f7e", crand="540ef65e", cnum="1", response="01000000711A1D4115CCCB8E64000000"
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,848" Module="network.sip" Level="INFO":  Dst-ip="127.0.0.1"  Dst-port="22410"   Detail="Sending Response Code=200, Method=NOTIFY, To=sip:lianzhao@ewellsoft.com, Call-ID=cea47db95f15840d@127.0.0.1"
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,848" Module="network.sip" Level="DEBUG":  Dst-ip="127.0.0.1"  Dst-port="22410"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 126 NOTIFY
Content-Length: 0
2012-11-26T10:26:18+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:18,849" Module="network.tcp" Level="DEBUG":  Src-ip="172.17.0.11" Src-port="50159" Dst-ip="172.16.50.3" Dst-port="5061" Detail="TCP Connection Closed"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,227" Module="network.tcp" Level="DEBUG":  Src-ip="172.17.0.11" Src-port="50160" Dst-ip="172.16.50.3" Dst-port="5061" Detail="TCP Connecting"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,229" Module="network.tcp" Level="DEBUG":  Src-ip="172.17.0.11" Src-port="50160" Dst-ip="172.16.50.3" Dst-port="5061" Detail="TCP Connection Established"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,441" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,441" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|REGISTER sip:ewellsoft.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKca3777cbe7b65476906c4b1cc7fab4c4.1;received=172.17.0.11;rport=50160
Call-ID: e5de4925e81a858d@172.17.0.11
CSeq: 49337 REGISTER
Contact: ;+sip.instance=""
From: <>lianzhao@ewellsoft.com>;tag=66057a872ab6448f
Max-Forwards: 70
Allow: INVITE,ACK,CANCEL,BYE,INFO,OPTIONS,REFER,NOTIFY
Expires: 3600
Supported: replaces,100rel,timer,gruu
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,442" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=401, Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,442" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
To: <>lianzhao@ewellsoft.com>;tag=43f09be159ef1d82
Server: TANDBERG/4120 (X7.2)
WWW-Authenticate: Digest realm="vcsc.ewellsoft.com", nonce="6d51e6764fccb80fbd928b65bf20fae7787c976bca331e270fe0cac6c071", opaque="AQAAACi1nkiZ68/UThGK5ErNz7Q52Z1G", stale=FALSE, algorithm=MD5, qop="auth"
WWW-Authenticate: NTLM realm="vcsc.ewellsoft.com", qop="auth", targetname="vcsc.ewellsoft.com"
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,521" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,521" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK5f95086d09b08b1153df39f3def2336f.1;received=172.17.0.11;rport=50160
CSeq: 49338 REGISTER
Max-Forwards: 70
Expires: 3600
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,521" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=401, Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,522" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
To: <>lianzhao@ewellsoft.com>;tag=5cdc82d3a842d6d3
WWW-Authenticate: NTLM realm="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", targetname="vcsc.ewellsoft.com", gssapi-data="TlRMTVNTUAACAAAAGgAaADgAAABRgpniqipzOA+WEBsAAAAAAAAAACIAIgBSAAAAAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAIAGgBFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAAAAAAA="
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,601" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,601" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKf15edaa8627b941ccf26ee3efc019f95.1;received=172.17.0.11;rport=50160
CSeq: 49339 REGISTER
Max-Forwards: 70
User-Agent: TANDBERG/774 (MCX 4.5.7.16762) - Mac OS X
Expires: 3600
Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", gssapi-data="TlRMTVNTUAADAAAAGAAYAEAAAABSAFIAWAAAABoAGgCqAAAAEAAQAMQAAAAWABYA1AAAABAAEADqAAAAVYKYYCwYHnlSSXsPYP/7Sd3FUGtmdOvMq2AdybYCsvK5LafxDcxbg5mhlKABAQAAAAAAAGIUVmt9y80BZnTrzKtgHckAAAAAAgAaAEUAVwBFAEwATABTAE8ARgBUAC4AQwBPAE0AAAAAAAAAAABFAFcARQBMAEwAUwBPAEYAVAAuAEMATwBNAGwAaQBhAG4AegBoAGEAbwAxADcAMgAuADEANwAuADAALgAxADEAXgakekH4hIGQKBMfhG8Q+w=="
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,602" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication request" client id="59" username="lianzhao" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,604" Module="network.rpcnetlogon" Level="DEBUG":  netlogon="rpc authentication succeeded" client id="59" username="lianzhao" domain="EWELLSOFT.COM" workstation="EWELLSOFT.COM" result="1" reason code="0x0 - No error" reason string=""
2012-11-26T10:26:19+08:00 vcsc tvcs: Event="Registration Requested" Service="SIP" Src-ip="172.17.0.11" Src-port="50160" Protocol="TLS" AOR="lianzhao@ewellsoft.com" Contact="sip:lianzhao@172.17.0.11:50160;transport\=tls" Duration="60" Level="1" UTCTime="2012-11-26 02:26:19,604"
2012-11-26T10:26:19+08:00 vcsc tvcs: Event="Registration Accepted" Service="SIP" Src-ip="172.17.0.11" Src-port="50160" Protocol="TLS" AOR="lianzhao@ewellsoft.com" Contact="sip:lianzhao@172.17.0.11:50160;transport\=tls" Duration="60" Level="1" UTCTime="2012-11-26 02:26:19,608"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,608" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=200, Method=REGISTER, To=sip:lianzhao@ewellsoft.com, Call-ID=e5de4925e81a858d@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,609" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
|SIP/2.0 200 OK
Contact: ;+sip.instance="";pub-gruu="sip:lianzhao@ewellsoft.com;gr=urn:uuid:6680f76e-5492-5a12-af2d-fd05e5dc972e";expires=60
To: <>lianzhao@ewellsoft.com>;tag=b86e076c025252d8
Date: Mon, 26 Nov 2012 02:26:19 GMT
Supported: com.tandberg.sdp.extensions.v1,gruu,outbound,path
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,612" Module="network.tcp" Level="DEBUG":  Dst-ip="172.16.50.22" Dst-port="80" Detail="TCP Connecting"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,613" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:4370/status/licensemanager/licensepool/license_type/registration" Ref="0x7f7ba14b5240"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,613" Module="network.tcp" Level="DEBUG":  Src-ip="172.16.50.3" Src-port="44553" Dst-ip="172.16.50.22" Dst-port="80" Detail="TCP Connection Established"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,614" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="4370" Dst-ip="127.0.0.1" Dst-port="45492" Response="200 OK" ResponseTime="0.001551" Ref="0x7f7ba14b5240"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,622" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:4370/status/registration/registration/uuid/a99d2ce2-3770-11e2-91d8-000c29f3450f" Ref="0x7f7ba14b5240"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,623" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="4370" Dst-ip="127.0.0.1" Dst-port="45492" Response="200 OK" ResponseTime="0.001417" Ref="0x7f7ba14b5240"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,691" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=PUBLISH, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,691" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|PUBLISH sip:lianzhao@ewellsoft.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK085bc3bdeaf90b0530eaf6e7d2b4dca6.1;received=172.17.0.11;rport=50160
Call-ID: fac97681468bf558@172.17.0.11
CSeq: 201 PUBLISH
Contact: <>lianzhao@ewellsoft.com;gr=urn:uuid:6680f76e-5492-5a12-af2d-fd05e5dc972e>
From: <>lianzhao@ewellsoft.com>;tag=01271b1dc8f26dfa
Max-Forwards: 70
Expires: 1800
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="69a2c4aa", cnum="2", response="0100000023865DF5A857307564000000"
Event: presence
Content-Type: application/pidf+xml
Content-Length: 583
     xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model"
     xmlns:rpid="urn:ietf:params:xml:ns:pidf:rpid"
     entity="sip:lianzhao@ewellsoft.com">
     open
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,697" Module="network.tcp" Level="DEBUG":  Src-ip="127.0.0.1" Src-port="25032" Dst-ip="127.0.0.1" Dst-port="2664" Detail="TCP Connecting"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,697" Module="network.tcp" Level="DEBUG":  Src-ip="127.0.0.1" Src-port="25032" Dst-ip="127.0.0.1" Dst-port="2664" Detail="TCP Connection Established"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,697" Module="network.sip" Level="INFO":  Dst-ip="127.0.0.1"  Dst-port="2664"   Detail="Sending Request Method=PUBLISH, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,697" Module="network.sip" Level="DEBUG":  Dst-ip="127.0.0.1"  Dst-port="2664"
SIPMSG:
Via: SIP/2.0/TCP 127.0.0.1:5060;egress-zone=DefaultZone;branch=z9hG4bK6f7fd283258757186039495d702391e547683.5b71af3b58f2cd05868e5866cc6c2c9d;proxy-call-id=a9aa884c-3770-11e2-976d-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK085bc3bdeaf90b0530eaf6e7d2b4dca6.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 201 PUBLISH
Max-Forwards: 69
Expires: 1800
Event: presence
X-TAATag: a9aa8b44-3770-11e2-b5af-000c29f3450f
Content-Length: 583
     open
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,698" Module="network.tcp" Level="DEBUG":  Src-ip="127.0.0.1" Src-port="25032" Dst-ip="127.0.0.1" Dst-port="2664" Detail="TCP Connection Established"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,698" Module="network.sip" Level="INFO":  Src-ip="127.0.0.1"  Src-port="25032"   Detail="Receive Request Method=PUBLISH, Request-URI=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,699" Module="network.sip" Level="DEBUG":  Src-ip="127.0.0.1"  Src-port="25032"
SIPMSG:
Via: SIP/2.0/TCP 127.0.0.1:5060;egress-zone=DefaultZone;branch=z9hG4bK6f7fd283258757186039495d702391e547683.5b71af3b58f2cd05868e5866cc6c2c9d;proxy-call-id=a9aa884c-3770-11e2-976d-000c29f3450f;received=127.0.0.1;rport=25032
CSeq: 201 PUBLISH
Max-Forwards: 69
Expires: 1800
Event: presence
Content-Length: 583
     open
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,699" Module="network.sip" Level="INFO":  Dst-ip="127.0.0.1"  Dst-port="25032"   Detail="Sending Response Code=200, Method=PUBLISH, To=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,699" Module="network.sip" Level="DEBUG":  Dst-ip="127.0.0.1"  Dst-port="25032"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 201 PUBLISH
To: <>lianzhao@ewellsoft.com>;tag=4831fd5a1ef5b88e
Expires: 1152
SIP-ETag: a9ab8df0-3770-11e2-ba37-000c29f3450f
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,700" Module="network.sip" Level="INFO":  Src-ip="127.0.0.1"  Src-port="2664"   Detail="Receive Response Code=200, Method=PUBLISH, To=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,700" Module="network.sip" Level="DEBUG":  Src-ip="127.0.0.1"  Src-port="2664"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 201 PUBLISH
Expires: 1152
Content-Length: 0
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,701" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=200, Method=PUBLISH, To=sip:lianzhao@ewellsoft.com, Call-ID=fac97681468bf558@172.17.0.11"
2012-11-26T10:26:19+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:19,701" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 201 PUBLISH
Expires: 1152
Content-Length: 0
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,572" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:j@jabber.com, Call-ID=c43096c24993f384@172.17.0.11"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,572" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|SUBSCRIBE sip:j@jabber.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK51b63859d695c982a12609f24f9b82a9.1;received=172.17.0.11;rport=50160
Call-ID: c43096c24993f384@172.17.0.11
CSeq: 302 SUBSCRIBE
From: <>lianzhao@ewellsoft.com>;tag=63cf7da2d11971b9
To: <>j@jabber.com>
Max-Forwards: 70
Expires: 3600
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="ddf44b63", cnum="3", response="01000000302001290C17D32364000000"
Event: presence
Accept: application/pidf+xml
Content-Length: 0
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,575" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,576" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,576" Module="network.search" Level="INFO":   Detail="Search rule 'internal' did not match destination alias 'j@jabber.com'"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,576" Module="network.search" Level="INFO":   Detail="Search rule 'External IP address search rule' did not match destination alias 'j@jabber.com'"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,576" Module="network.search" Level="INFO":   Detail="Considering search rule 'Traversal zone search rule' towards target 'TraversalZone' at priority '100' with alias 'j@jabber.com'"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,580" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:j@jabber.com, Call-ID=c43096c24993f384@172.17.0.11"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,580" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bKc2419cb73c21af7a0ca67466897d731247684.1fd1eaec1ed990bdc5f3a751290be3c2;proxy-call-id=aa30e090-3770-11e2-afd7-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK51b63859d695c982a12609f24f9b82a9.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 302 SUBSCRIBE
To: <>j@jabber.com>
Max-Forwards: 15
Expires: 3600
Event: presence
X-TAATag: aa30e37e-3770-11e2-b6ee-000c29f3450f
Content-Length: 0
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,997" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=404, Method=SUBSCRIBE, To=sip:j@jabber.com, Call-ID=c43096c24993f384@172.17.0.11"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,997" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
|SIP/2.0 404 Not Found
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bKc2419cb73c21af7a0ca67466897d731247684.1fd1eaec1ed990bdc5f3a751290be3c2;proxy-call-id=aa30e090-3770-11e2-afd7-000c29f3450f;received=172.16.50.3;rport=25031;ingress-zone=TraversalZone
CSeq: 302 SUBSCRIBE
To: <>j@jabber.com>;tag=a3c3c59ff653078a
Warning: 399 172.16.5.10:7001 "Policy Response"
Content-Length: 0
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,999" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:j@jabber.com, Call-ID=c43096c24993f384@172.17.0.11"
2012-11-26T10:26:20+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:20,999" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
CSeq: 302 SUBSCRIBE
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:allen.fan@jabber.com, Call-ID=f739cbb8bb269444@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|SUBSCRIBE sip:allen.fan@jabber.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKa00eb7b22e02142ea213c372d17a1811.1;received=172.17.0.11;rport=50160
Call-ID: f739cbb8bb269444@172.17.0.11
CSeq: 402 SUBSCRIBE
From: <>lianzhao@ewellsoft.com>;tag=0e170bd7cc825f2a
To: <>allen.fan@jabber.com>
Max-Forwards: 70
Expires: 3600
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="319ba806", cnum="4", response="010000004D9485191694777E64000000"
Event: presence
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.search" Level="INFO":   Detail="Search rule 'internal' did not match destination alias 'allen.fan@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.search" Level="INFO":   Detail="Search rule 'External IP address search rule' did not match destination alias 'allen.fan@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,079" Module="network.search" Level="INFO":   Detail="Considering search rule 'Traversal zone search rule' towards target 'TraversalZone' at priority '100' with alias 'allen.fan@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,090" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:allen.fan@jabber.com, Call-ID=f739cbb8bb269444@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,090" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK3f97514b9467b8c439fa21d95689d63c47685.175012368681c620fcb99a487dfe08e2;proxy-call-id=aa7e32d2-3770-11e2-90f4-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKa00eb7b22e02142ea213c372d17a1811.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 402 SUBSCRIBE
Max-Forwards: 15
Expires: 3600
Event: presence
X-TAATag: aa7e32d2-3770-11e2-8ce4-000c29f3450f
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,173" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=404, Method=SUBSCRIBE, To=sip:allen.fan@jabber.com, Call-ID=f739cbb8bb269444@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,173" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK3f97514b9467b8c439fa21d95689d63c47685.175012368681c620fcb99a487dfe08e2;proxy-call-id=aa7e32d2-3770-11e2-90f4-000c29f3450f;received=172.16.50.3;rport=25031;ingress-zone=TraversalZone
CSeq: 402 SUBSCRIBE
To: <>allen.fan@jabber.com>;tag=01eb0ecf53bc97fd
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,175" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:allen.fan@jabber.com, Call-ID=f739cbb8bb269444@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,176" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
CSeq: 402 SUBSCRIBE
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,255" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:stzheng@jabber.com, Call-ID=6a28dd321a48a5eb@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,255" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|SUBSCRIBE sip:stzheng@jabber.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK36b2418931f6274ad5d9ee4724907a41.1;received=172.17.0.11;rport=50160
Call-ID: 6a28dd321a48a5eb@172.17.0.11
CSeq: 502 SUBSCRIBE
From: <>lianzhao@ewellsoft.com>;tag=90b15ead2fc01245
To: <>stzheng@jabber.com>
Max-Forwards: 70
Expires: 3600
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="083ae67c", cnum="5", response="01000000309CD5FDFC0188A664000000"
Event: presence
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,258" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,259" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,260" Module="network.search" Level="INFO":   Detail="Search rule 'internal' did not match destination alias 'stzheng@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,260" Module="network.search" Level="INFO":   Detail="Search rule 'External IP address search rule' did not match destination alias 'stzheng@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,260" Module="network.search" Level="INFO":   Detail="Considering search rule 'Traversal zone search rule' towards target 'TraversalZone' at priority '100' with alias 'stzheng@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,263" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:stzheng@jabber.com, Call-ID=6a28dd321a48a5eb@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,264" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK400f9d070480603411301a96256e274d47686.b9d2bbbeb12aaa3e14f4c28db95ff7b6;proxy-call-id=aa9923a8-3770-11e2-9e7b-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK36b2418931f6274ad5d9ee4724907a41.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 502 SUBSCRIBE
Max-Forwards: 15
Expires: 3600
Event: presence
X-TAATag: aa9926a0-3770-11e2-a29a-000c29f3450f
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,307" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=404, Method=SUBSCRIBE, To=sip:stzheng@jabber.com, Call-ID=6a28dd321a48a5eb@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,307" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK400f9d070480603411301a96256e274d47686.b9d2bbbeb12aaa3e14f4c28db95ff7b6;proxy-call-id=aa9923a8-3770-11e2-9e7b-000c29f3450f;received=172.16.50.3;rport=25031;ingress-zone=TraversalZone
CSeq: 502 SUBSCRIBE
To: <>stzheng@jabber.com>;tag=c9bb707e77fced71
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,309" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:stzheng@jabber.com, Call-ID=6a28dd321a48a5eb@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,309" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
CSeq: 502 SUBSCRIBE
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,389" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:qiyong@jabber.com, Call-ID=934b3950d889bbe9@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,389" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|SUBSCRIBE sip:qiyong@jabber.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK65c9887e1cfcd9accc3b0e2260dc7dd4.1;received=172.17.0.11;rport=50160
Call-ID: 934b3950d889bbe9@172.17.0.11
CSeq: 602 SUBSCRIBE
From: <>lianzhao@ewellsoft.com>;tag=de260c3458a1bf9f
To: <>qiyong@jabber.com>
Max-Forwards: 70
Expires: 3600
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="9bf88705", cnum="6", response="0100000054D25BA12D0AC0B364000000"
Event: presence
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,392" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,393" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,394" Module="network.search" Level="INFO":   Detail="Search rule 'internal' did not match destination alias 'qiyong@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,394" Module="network.search" Level="INFO":   Detail="Search rule 'External IP address search rule' did not match destination alias 'qiyong@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,394" Module="network.search" Level="INFO":   Detail="Considering search rule 'Traversal zone search rule' towards target 'TraversalZone' at priority '100' with alias 'qiyong@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,397" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:qiyong@jabber.com, Call-ID=934b3950d889bbe9@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,397" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK3a5aeae080ed9a4a4fa9030d8dd6814a47687.19f3246eebee55842116f91b3bb02722;proxy-call-id=aaad9220-3770-11e2-a851-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bK65c9887e1cfcd9accc3b0e2260dc7dd4.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 602 SUBSCRIBE
Max-Forwards: 15
Expires: 3600
Event: presence
X-TAATag: aaad9504-3770-11e2-a6b2-000c29f3450f
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,438" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=404, Method=SUBSCRIBE, To=sip:qiyong@jabber.com, Call-ID=934b3950d889bbe9@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,439" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK3a5aeae080ed9a4a4fa9030d8dd6814a47687.19f3246eebee55842116f91b3bb02722;proxy-call-id=aaad9220-3770-11e2-a851-000c29f3450f;received=172.16.50.3;rport=25031;ingress-zone=TraversalZone
CSeq: 602 SUBSCRIBE
To: <>qiyong@jabber.com>;tag=a7467ab30bdd168e
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,441" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:qiyong@jabber.com, Call-ID=934b3950d889bbe9@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,441" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
CSeq: 602 SUBSCRIBE
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,520" Module="network.sip" Level="INFO":  Src-ip="172.17.0.11"  Src-port="50160"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:jiangs@jabber.com, Call-ID=dd2083b8b4008f8c@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,520" Module="network.sip" Level="DEBUG":  Src-ip="172.17.0.11"  Src-port="50160"
SIPMSG:
|SUBSCRIBE sip:jiangs@jabber.com SIP/2.0
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKcd775d14b793d03ccd12393293feca17.1;received=172.17.0.11;rport=50160
Call-ID: dd2083b8b4008f8c@172.17.0.11
CSeq: 702 SUBSCRIBE
From: <>lianzhao@ewellsoft.com>;tag=0d42d9351eae4b76
To: <>jiangs@jabber.com>
Max-Forwards: 70
Expires: 3600
Proxy-Authorization: NTLM qop="auth", realm="vcsc.ewellsoft.com", targetname="vcsc.ewellsoft.com", opaque="1b10960f38732aaa", crand="0b24d920", cnum="7", response="01000000AF78F79A6022742B64000000"
Event: presence
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,523" Module="network.cpl" Level="DEBUG":  Remote-ip="172.17.0.11"  Remote-port="50160"   Detail="CPL: "
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,524" Module="network.search" Level="INFO":   Detail="Search rule 'internal' did not match destination alias 'jiangs@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,524" Module="network.search" Level="INFO":   Detail="Search rule 'External IP address search rule' did not match destination alias 'jiangs@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,524" Module="network.search" Level="INFO":   Detail="Considering search rule 'Traversal zone search rule' towards target 'TraversalZone' at priority '100' with alias 'jiangs@jabber.com'"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,528" Module="network.sip" Level="INFO":  Dst-ip="172.16.5.10"  Dst-port="7001"   Detail="Sending Request Method=SUBSCRIBE, Request-URI=sip:jiangs@jabber.com, Call-ID=dd2083b8b4008f8c@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,528" Module="network.sip" Level="DEBUG":  Dst-ip="172.16.5.10"  Dst-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK13e465e097e746b349db4e530a2d550447688.63ee93328210d0a80d9def9dbe141d34;proxy-call-id=aac186fe-3770-11e2-a0b8-000c29f3450f;rport
Via: SIP/2.0/TLS 172.17.0.11:50160;branch=z9hG4bKcd775d14b793d03ccd12393293feca17.1;received=172.17.0.11;rport=50160;ingress-zone=DefaultSubZone
CSeq: 702 SUBSCRIBE
Max-Forwards: 15
Expires: 3600
Event: presence
X-TAATag: aac1897e-3770-11e2-b41c-000c29f3450f
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,576" Module="network.sip" Level="INFO":  Src-ip="172.16.5.10"  Src-port="7001"   Detail="Receive Response Code=404, Method=SUBSCRIBE, To=sip:jiangs@jabber.com, Call-ID=dd2083b8b4008f8c@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,577" Module="network.sip" Level="DEBUG":  Src-ip="172.16.5.10"  Src-port="7001"
SIPMSG:
Via: SIP/2.0/TLS 172.16.50.3:5061;egress-zone=TraversalZone;branch=z9hG4bK13e465e097e746b349db4e530a2d550447688.63ee93328210d0a80d9def9dbe141d34;proxy-call-id=aac186fe-3770-11e2-a0b8-000c29f3450f;received=172.16.50.3;rport=25031;ingress-zone=TraversalZone
CSeq: 702 SUBSCRIBE
To: <>jiangs@jabber.com>;tag=2882b8ec6f10e4bf
Content-Length: 0
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,579" Module="network.sip" Level="INFO":  Dst-ip="172.17.0.11"  Dst-port="50160"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:jiangs@jabber.com, Call-ID=dd2083b8b4008f8c@172.17.0.11"
2012-11-26T10:26:21+08:00 vcsc tvcs: UTCTime="2012-11-26 02:26:21,579" Module="network.sip" Level="DEBUG":  Dst-ip="172.17.0.11"  Dst-port="50160"
SIPMSG:
CSeq: 702 SUBSCRIBE
Content-Length: 0
2012-11-26T10:26:22+08:00 vcsc httpd[7079]: web: Event="Diagnostic Logging" Detail="Logging stopped; DEBUG_MARKER:" UTCTime="2012-11-26 02:26:22"
2012-11-26T10:26:22+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/end_time - changed from: '0' to: '1353896782'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:22"
2012-11-26T10:26:22+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/loggingsnapshot/saved_log_levels - changed from: '{'network':'INFO','developer.iwf':'INFO'}' to: '{}'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:22"
2012-11-26T10:26:22+08:00 vcsc httpd[7079]: web: Event="System Configuration Changed" Detail="configuration/networklogger/uuid/b7296014-1f57-11e2-a0cf-000c29f3450f/level - changed from: 'DEBUG' to: 'INFO'" Src-ip="172.17.0.11" Src-port="50158" User="admin" Level="1" UTCTime="2012-11-26 02:26:22"
stop log
BTW, I'm not sure whether my search rule settings in VCSE are correct, so I've pasted below, pls help to take a look, I felt the request didn't pass to VCSc from VCSe:
VCS-E is challenging user authentication locally without forwarding subscribe request to VCS-C (where I believe you have configured AD server link for credential challenge).
2nd search rule in search history should forward subscribe/provisioning message to VCS-C (if TraversalZone is for your VCS-C) as long as “Request must be authenticated” set to “No” (default parameter is “No”).
Do you see any configuration if you execute “xconfig sip route” command on VCS-E (which should not see any route configuration on VCS-E)?
Do you have any zone/subzone in VCS-E other than “Do not check credential” for Authentication policy?
Hi, Tomonori
I do had configured AD in the VCSE, but I've turned that off already before the above test, see below for the AD configuration:
Tomonori Taniguchi 编写:
Yes, that's correct, the "Reqest must be authenticated" for the TraversalZoneSearch rule it set to No.
See below for all the Zones in my VCS-E, and I havn't configured any subzone in the VCSE, and defaultsubzone set to no authenticate:
Do you see any SIP routing configuration if you execute “xconfig sip route” command  on VCS-E (which should not see any route configuration on VCS-E)?
I tried by login to VCSE by SSH, and I found there isn't any output:
Last login: Mon Nov 26 11:32:19 CST 2012 from 172.17.0.11 on pts/0
Welcome to vcse
TANDBERG VCS Release X7.2
SW Release Date: 2012-07-13
OK
xconfiguration sip route
OK
OK, that is expected out come as well.
I’d suggest you to open TAC case for further investigation with log and remote session with your environment (may not good idea to carry on this discussion on public forum and have further investigation with customer credential information).
