Video call from 9971 on CUBE from 800 series ISR
Kjetil Fleten
We want to setup a 800 series ISR with CUBE and a 9971 phone with camera to make video calls to remote locations equiped with different versions of Call manager and  E20 phones. We intend to use SIP on our side of the connection.
Is this possible with a 800 series ISR, or is it any limitations that we should be aware of ?
As above: to use video endpoints with CUCM, a CUBE/SBC is not necessarily needed.
Thanks for the nice rating and good luck!
paolo bevilacqua
For doing calls (video or not), between different call managers, one does't necessarily need CUBE/SBC.
That being said, CUBE/SBC on the 800 series works the same as on other routers.
Thanks for your reply. You say I don't necessarily need CUBE between call managers; in this scenario our location does not have a call manager at all: Only CUBE. We want to call remote locations that have call manager. So the qestion is more if CUBE (without any call manager) is enough ?
