video call with CME 2921
ahmed_843
first I am very happy for being part of a Cisco community
i have 6 international site in each site  the user  from 10 to 15 , and i need use video call between these sits , (now the scenario)> i but in each site call manager express ( CME ) 2921 with 1 GB DRAM , all sites connect with each other Through E1 conection  ,  please advice me about this Questions
1- CME can work with vedio call
2- wich IOS version i need for video Feature
3- The CME 2921 Enough or i need better box
and thx for help ....
6 Replies 6
Vishal Mohanty
Hello Ahmed,
Welcome to the Cisco family!! :-)
To answer your questions:
1) Yes CME supports Video calls; as usual there are some restrictions and some pre-requisites. I would suggest to go through the feature document that will answer your questions in detail:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevideo.html#wp1012200
2) I would suggest 15.1(4)M or 15.1(4)M1 (which will be coming out in the later part of June). This IOS version will give you the lastets version of CME 8.6. The above document also lists the minimum CME versions required for Video support in case you do not prefer to use 15.1(4)M at this point of time.
FYI, this page shows your what CME version is in what IOS version and its specifications and also has links to the documentation and release notes:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
3) 2921 should work fine.
Hope this helps,
Vishal
If you follow Vishal's suggestion about using IOS 15.1(4)M, you could use IOS video conferencing/transcoding services on the ISR G2 with PVDM3 (then you don't need MCU).
Video Conferences:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevconf.pdf
Video xcoding:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevtrns.pdf
Hope it helps, please rate if it does.
-- Adrian.
mohammad saeed
Level 5
Level 5
the links are down, is there any links updated? Thanks
If you mean the ones Adrian posted, those features have been deprecated for many years now, that's why documentation no longer exists.
java
if this helps, please rate
Hi Jaime, So is there any updated documents regarding using Video with CME?
The CME admin guide.
java
