05-16-2011 11:54 AM - edited 03-17-2019 10:18 PM
I need advice. There is such configuration : CME_A <- h323 INTERNET h323 -> CME_B <-h323-> CUCM7.1
When i put a video call(from CME_A & session target CME_B) everything is ok - called and calling party can see each other. But when i receive a call(from CUCM + gateway CME_A) i see the calling party but he doesnt see me.
When I change gateway of the route pattern on the CUCM server from CME_A to CME_B i recevice the call but i dont hear/see anything.
What can be the problem?
Thank you in advance.
06-23-2011 12:00 PM
Here is another info - debug from CME_A(7.1 version) while call is being answered. There is no video from CUCM user. CME user can see remote CUCM user.
debug cch323 video
debug h225 asn1
debug h245 asn1
debug voip ccapi inout
Could you help me understand it, please look into the trace. Thank you in advance.
013080: *Jun 20 17:49:48.911 : //850/80DD1AF00500/CCAPI/cc_api_call_connected:
Interface=0x315D253C, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
013081: *Jun 20 17:49:48.911 : //850/80DD1AF00500/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
013082: *Jun 20 17:49:48.915 : //849/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x31274E90, callID1=0x351, callID2=0x352, tag=0x0)
013083: *Jun 20 17:49:48.915 : //849/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x31274E90, callID1=0x351, gcid=0-0-0-0, tag=0x0)
013084: *Jun 20 17:49:48.915 : //850/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x31274E90, callID2=0x352, gcid=0-0-0-0, tag=0x0)
013085: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/ccConferenceCreate:
Conference Id=0x31274E90, Call Id1=849, Call Id2=850, Tag=0x0
013086: *Jun 20 17:49:48.915 : //849/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
013087: *Jun 20 17:49:48.915 : cc_api_get_xcode_stream : 4534
013088: *Jun 20 17:49:48.915 : //849/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xA6, Source Interface=0x30C4D994, Source Call Id=849,
Destination Call Id=850, Disposition=0x0, Tag=0x0
013089: *Jun 20 17:49:48.915 : //850/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xA6, Source Interface=0x315D253C, Source Call Id=850,
Destination Call Id=849, Disposition=0x0, Tag=0xFFFFFFFF
013090: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/cc_generic_bridge_done:
013091: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xA6, Destination Call Id=850)
013092: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xA6, Destination Call Id=849)
013093: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/cc_api_caps_ind:
Destination Interface=0x30C4D994, Destination Call Id=849, Source Call Id=850,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x0, Codec Bytes=20, Signal Type=3)
013094: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
013095: *Jun 20 17:49:48.915 : //-1/xxxxxxxxxxxx/H323/cch323_post_caps_ind: callID=849, ExtendedCaps not present
013096: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
013097: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
013098: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
013099: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/ccCallFeature:
Feature Type=25, Call Id=850
013100: *Jun 20 17:49:48.915 : //849/80DD1AF00500/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=849
013101: *Jun 20 17:49:48.915 : //850/80DD1AF00500/CCAPI/cc_api_get_called_ccm_detected:
013102: *Jun 20 17:49:48.915 : H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body connect :
protocolIdentifier { 0 0 8 2250 0 4 }
h245Address ipAddress :
ip '0A008B37'H
port 33741
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
conferenceID '80DD1AF0F04DF1DF0500AD01AC109862'H
callIdentifier
guid '80DD1AF0F04DF1DF0500AD01AC109862'H
multipleCalls FALSE
maintainConnection FALSE
h245Tunneling FALSE
013103: *Jun 20 17:49:48.919 : H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000A008B3783CD2800B500001240013C0501000080DD1AF0F04DF1DF0500AD01AC1098621D0C00110080DD1AF0F04DF1DF0500AD01AC1098620100010010800100
013104: *Jun 20 17:49:48.919 :
013105: *Jun 20 17:49:48.919 : H225.0 OUTGOING PDU ::=
h323-uu-pdu
h323-message-body notify :
callIdentifier
h245Tunneling FALSE
013106: *Jun 20 17:49:48.919 : H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040080DD1AF0F04DF1DF0500AD01AC10986210800100
013107: *Jun 20 17:49:48.919 :
013108: *Jun 20 17:49:48.919 : //849/80DD1AF00500/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xA6, Call Id1=849, Call Id2=850
013109: *Jun 20 17:49:48.963 : //849/80DD1AF00500/H323/cch323_h245_connection_sm: state=1, event=2, ccb=29EEFA44, listen state=1
013110: *Jun 20 17:49:48.963 : //849/80DD1AF00500/H323/cch323_send_cap_request: Setting mode to VIDEO MODE
013111: *Jun 20 17:49:48.963 : //849/80DD1AF00500/H323/cch323_prepare_video_codec_list: cch323_prepare_video_codec_list: num_of_caps: 2
013112: *Jun 20 17:49:48.963 : //-1/xxxxxxxxxxxx/H323/cch323_filtered_video_cap_present: cch323_filtered_video_cap_present Match found for H.263
013113: *Jun 20 17:49:48.963 : H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 7 }
multiplexCapability h2250Capability :
maximumAudioDelayJitter 20
receiveMultipointCapability
multicastCapability FALSE
multiUniCastConference FALSE
mediaDistributionCapability
centralizedControl FALSE
distributedControl FALSE
centralizedAudio FALSE
distributedAudio FALSE
centralizedVideo FALSE
distributedVideo FALSE
transmitMultipointCapability
receiveAndTransmitMultipointCapability
mcCapability
centralizedConferenceMC FALSE
decentralizedConferenceMC FALSE
rtcpVideoControlCapability FALSE
mediaPacketizationCapability
h261aVideoPacketization FALSE
rtpPayloadType
payloadDescriptor oid : { 0 0 8 241 0 0 0 0 }
logicalChannelSwitchingCapability FALSE
t120DynamicPortCapability FALSE
capabilityTable
capabilityTableEntryNumber 32
capability receiveAndTransmitDataApplicationCapability :
application t38fax :
t38FaxProtocol udp : NULL
t38FaxProfile
fillBitRemoval FALSE
transcodingJBIG FALSE
transcodingMMR FALSE
version 0
t38FaxRateManagement transferredTCF : NULL
t38FaxUdpOptions
t38FaxMaxBuffer 200
t38FaxMaxDatagram 72
t38FaxUdpEC t38UDPRedundancy : NULL
maxBitRate 144
capabilityTableEntryNumber 27
capability receiveUserInputCapability : basicString : NULL
capability receiveAudioCapability : g711Ulaw64k : 20
capabilityTableEntryNumber 4
capability receiveAudioCapability : g711Alaw64k : 20
capabilityTableEntryNumber 40
capability receiveVideoCapability : genericVideoCapability :
capabilityIdentifier standard : { 0 0 8 241 0 0 1 }
maxBitRate 500
collapsing
parameterIdentifier standard : 41
parameterValue booleanArray : 64
parameterIdentifier standard : 42
parameterValue unsignedMin : 50
capabilityTableEntryNumber 39
capability receiveVideoCapability : h263VideoCapability :
qcifMPI 1
cifMPI 1
maxBitRate 500
unrestrictedVector FALSE
arithmeticCoding FALSE
advancedPrediction FALSE
pbFrames FALSE
temporalSpatialTradeOffCapability FALSE
errorCompensation FALSE
capabilityDescriptors
capabilityDescriptorNumber 1
simultaneousCapabilities
32,
3,
40
27
013114: *Jun 20 17:49:48.971 : H245 MSC OUTGOING ENCODE BUFFER::= 02700106000881750007802080001400010000010000010004020B00100800088171000000000660010001000580001F4A0811860100807C0100014007C00200C8014840009080001A83011080000220C0138000032040138000270C0015600007000881710000014001F40202914002A2003280002609D8000801F300704001000080010202001F00020003010026002700001A
013115: *Jun 20 17:49:48.971 :
013116: *Jun 20 17:49:48.971 : H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
terminalType 60
statusDeterminationNumber 8336
013117: *Jun 20 17:49:48.971 : H245 MSC OUTGOING ENCODE BUFFER::= 01003C402090
013118: *Jun 20 17:49:48.971 :
013119: *Jun 20 17:49:48.995 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 132
013120: *Jun 20 17:49:48.995 : H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC00100010006800000860A0000070008824301030180000120C02780000219D800080EFF00704001008000031C001560000700088171000001400F000202914002A2003280000485014080000585011080002B850150008000030000010100020003010004000500002B
013121: *Jun 20 17:49:48.995 :
013122: *Jun 20 17:49:48.995 : H245 MSC INCOMING PDU ::=
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 10 }
maximumAudioDelayJitter 60
mcCapability
capabilityTable
capabilityTableEntryNumber 1
capability genericControlCapability :
capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
capability receiveAudioCapability : g711Ulaw64k : 40
capability receiveAndTransmitVideoCapability : h263VideoCapability :
qcifMPI 1
cifMPI 1
maxBitRate 3840
pbFrames FALSE
capability receiveAndTransmitVideoCapability : genericVideoCapability :
maxBitRate 3840
collapsing
capabilityTableEntryNumber 5
capability receiveAndTransmitUserInputCapability : dtmf : NULL
capabilityTableEntryNumber 6
capability receiveAndTransmitUserInputCapability : basicString : NULL
capabilityTableEntryNumber 44
capability receiveAndTransmitUserInputCapability : hookflash : NULL
capabilityDescriptorNumber 0
6
44
013123: *Jun 20 17:49:49.003 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013124: *Jun 20 17:49:49.003 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013125: *Jun 20 17:49:49.003 : //849/80DD1AF00500/H323/cch323_h245_cap_ind: Masks au=0x1 data=0x0 uinp=0x32
013126: *Jun 20 17:49:49.003 : //849/80DD1AF00500/H323/cch323_h245_cap_ind: Updating video caps from remote TCS
013127: *Jun 20 17:49:49.003 : //-1/xxxxxxxxxxxx/H323/cch323_filtered_video_cap_present: cch323_filtered_video_cap_present Match found for H.263
013128: *Jun 20 17:49:49.003 : //849/80DD1AF00500/H323/cch323_do_multimedia_caps_ind: Sending event CC_EV_H245_MULTIMEDIA_CAPS_IND
013129: *Jun 20 17:49:49.003 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=166, Call Id=849
013130: *Jun 20 17:49:49.003 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
013131: *Jun 20 17:49:49.003 : H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
sequenceNumber 1
013132: *Jun 20 17:49:49.003 : H245 MSC OUTGOING ENCODE BUFFER::= 218001
013133: *Jun 20 17:49:49.003 :
013134: *Jun 20 17:49:49.003 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
013135: *Jun 20 17:49:49.003 : H245 MSC INCOMING ENCODE BUFFER::= 218001
013136: *Jun 20 17:49:49.003 :
013137: *Jun 20 17:49:49.003 : H245 MSC INCOMING PDU ::=
sequenceNumber 1
013138: *Jun 20 17:49:49.003 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013139: *Jun 20 17:49:49.003 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013140: *Jun 20 17:49:49.027 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
013141: *Jun 20 17:49:49.027 : H245 MSC INCOMING ENCODE BUFFER::= 2080
013142: *Jun 20 17:49:49.027 :
013143: *Jun 20 17:49:49.027 : H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
decision master : NULL
013144: *Jun 20 17:49:49.027 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013145: *Jun 20 17:49:49.027 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013146: *Jun 20 17:49:49.027 : H245 MSC OUTGOING PDU ::=
decision slave : NULL
013147: *Jun 20 17:49:49.027 : H245 MSC OUTGOING ENCODE BUFFER::= 20A0
013148: *Jun 20 17:49:49.027 :
013149: *Jun 20 17:49:49.027 : //849/80DD1AF00500/H323/cch323_generic_open_logical_channel: current codec = 5:160:160
013150: *Jun 20 17:49:49.027 : H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
forwardLogicalChannelNumber 1
forwardLogicalChannelParameters
dataType audioData : g711Ulaw64k : 20
multiplexParameters h2250LogicalChannelParameters :
sessionID 1
mediaControlChannel unicastAddress : iPAddress :
network '0A008B37'H
tsapIdentifier 20941
silenceSuppression FALSE
013151: *Jun 20 17:49:49.027 : H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B050001000A008B3751CD00
013152: *Jun 20 17:49:49.027 :
013153: *Jun 20 17:49:49.051 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
013154: *Jun 20 17:49:49.051 : H245 MSC INCOMING ENCODE BUFFER::= 030000000C6013800B05000100AC1098FE0FA100
013155: *Jun 20 17:49:49.051 :
013156: *Jun 20 17:49:49.051 : H245 MSC INCOMING PDU ::=
sessionID 1
network 'AC1098FE'H
tsapIdentifier 4001
013157: *Jun 20 17:49:49.051 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013158: *Jun 20 17:49:49.051 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013159: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: chan_type 1: chan_num 1
013160: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_h245_find_r_allocate_olc_instance: Using existing OLC instance
013161: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: channel_number: 1
013162: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: h245_rport_tx using RTCP port
013163: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/h245_iwf_validate_olc: ch=1 non-besteffort=0 sync=0 is_ipip=0, nonsync_rsvp=0
013164: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/h245_iwf_validate_olc: chanNum 1 BW tx:rx(640:640) is not a passthru channel
013165: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_do_cap_ind: Sending caps to the other leg, context = 29E5B160
013166: *Jun 20 17:49:49.051 : //849/80DD1AF00500/CCAPI/cc_api_caps_ind:
Destination Interface=0x315D253C, Destination Call Id=850, Source Call Id=849,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
013167: *Jun 20 17:49:49.051 : //849/80DD1AF00500/CCAPI/cc_api_caps_ind:
013168: *Jun 20 17:49:49.051 : //849/80DD1AF00500/H323/cch323_do_cap_ind: Sending caps_ack because NTFY DSP set
013169: *Jun 20 17:49:49.051 : //849/80DD1AF00500/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8357)
013170: *Jun 20 17:49:49.051 : H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
mediaChannel unicastAddress : iPAddress :
network '0A008B37'H
tsapIdentifier 20940
network '0A008B37'H
flowControlToZero FALSE
013171: *Jun 20 17:49:49.055 : H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C000A008B3751CC000A008B3751CD03000100
013172: *Jun 20 17:49:49.055 :
013173: *Jun 20 17:49:49.055 : //850/80DD1AF00500/CCAPI/cc_api_caps_ack:
013174: *Jun 20 17:49:49.055 : //849/80DD1AF00500/H323/cch323_peer_caps_ack: Sending caps resp event to CAP sm
013175: *Jun 20 17:49:49.055 : //850/80DD1AF00500/CCAPI/cc_api_voice_mode_event:
Call Id=850
013176: *Jun 20 17:49:49.055 : //850/80DD1AF00500/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x3155BF68)
013177: *Jun 20 17:49:49.055 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=156, Call Id=850
013178: *Jun 20 17:49:49.055 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
013179: *Jun 20 17:49:49.055 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=849
013180: *Jun 20 17:49:49.055 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_OPEN_CHANNEL_IND received, channelInfo ptr 0x29E88DF4
013181: *Jun 20 17:49:49.055 : //-1/xxxxxxxxxxxx/H323/cch323_open_channel_ind: Entry, callID=849
013182: *Jun 20 17:49:49.055 : //849/80DD1AF00500/H323/cch323_h245_get_olc_instance: cch323_h245_get_olc_instance - channel_type 2 sess_id 2 chn_num 2
013183: *Jun 20 17:49:49.055 : //849/80DD1AF00500/H323/cch323_h245_get_olc_instance: Allocated new OLC instance
013184: *Jun 20 17:49:49.055 : H245 MSC OUTGOING PDU ::=
forwardLogicalChannelNumber 2
dataType videoData : genericVideoCapability :
maxBitRate 500
collapsing
sessionID 2
network '0A008B37'H
tsapIdentifier 27635
dynamicRTPPayloadType 119
mediaPacketization rtpPayloadType :
payloadType 119
013185: *Jun 20 17:49:49.059 : H245 MSC OUTGOING ENCODE BUFFER::= 030000010A0015600007000881710000014001F40202914002A200328018046002000A008B376BF3BC000B50080008817100000000EE
013186: *Jun 20 17:49:49.059 :
013187: *Jun 20 17:49:49.059 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 41
013188: *Jun 20 17:49:49.059 : H245 MSC INCOMING ENCODE BUFFER::= 030000010A0015600007000881710000014001F40202914002A20032800B05400200AC1098FE0FA304
013189: *Jun 20 17:49:49.059 :
013190: *Jun 20 17:49:49.059 : H245 MSC INCOMING PDU ::=
maxBitRate 500
collapsing
sessionID 2
network 'AC1098FE'H
tsapIdentifier 4003
dynamicRTPPayloadType 97
013191: *Jun 20 17:49:49.059 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013192: *Jun 20 17:49:49.059 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013193: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: chan_type 2: chan_num 2
013194: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/cch323_h245_find_r_allocate_olc_instance: Using existing OLC instance
013195: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: channel_number: 2
013196: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/cch323_h245_uchan_ind: h245_rport_tx using RTCP port
013197: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/h245_iwf_validate_olc: allow video OLC for TDM-IP
013198: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/h245_iwf_build_olc_temp_channel_array: tempChannelArray=0x29E88DF4
013199: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/h245_iwf_validate_olc: ch=2 non-besteffort=0 sync=0 is_ipip=0, nonsync_rsvp=0
013200: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/h245_iwf_validate_olc: chanNum 2 BW tx:rx(500:500) is not a passthru channel
013201: *Jun 20 17:49:49.059 : //849/80DD1AF00500/H323/cch323_do_open_channel_ind: Sending event CC_EV_H245_OPEN_CHANNEL_IND, channelInfo pointer 0x29E88DF4
013202: *Jun 20 17:49:49.059 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=156, Call Id=849
013203: *Jun 20 17:49:49.059 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
013204: *Jun 20 17:49:49.059 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=157, Call Id=850
013205: *Jun 20 17:49:49.059 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
013206: *Jun 20 17:49:49.059 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=849
013207: *Jun 20 17:49:49.059 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_OPEN_CHANNEL_ACK received, channelInfo ptr 0x29E88DF4
013208: *Jun 20 17:49:49.059 : //-1/xxxxxxxxxxxx/H323/cch323_open_channel_ack: callID=849, Channel info: codec=-1 rtp=4002 rtcp=4003 aadr=172.16.152.254
013209: *Jun 20 17:49:49.063 : //-1/xxxxxxxxxxxx/H323/cch323_peer_channel_ack: cch323_peer_channel_ack olc_ptr->in_lcn 1 and ev->channelNumber 2
013210: *Jun 20 17:49:49.063 : //-1/xxxxxxxxxxxx/H323/cch323_peer_channel_ack: cch323_peer_channel_ack olc_ptr->in_lcn 2 and ev->channelNumber 2
013211: *Jun 20 17:49:49.063 : //849/80DD1AF00500/H323/h323_open_add_video_rtp_stream: ip_video_tos 136
013212: *Jun 20 17:49:49.063 : H245 MSC OUTGOING PDU ::=
network '0A008B37'H
tsapIdentifier 27634
network '0A008B37'H
013213: *Jun 20 17:49:49.063 : H245 MSC OUTGOING ENCODE BUFFER::= 22C000010680134C000A008B376BF2000A008B376BF303000100
013214: *Jun 20 17:49:49.063 :
013215: *Jun 20 17:49:49.099 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
013216: *Jun 20 17:49:49.099 : H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C0000AC1098625FC800AC1098625FC9
013217: *Jun 20 17:49:49.099 :
013218: *Jun 20 17:49:49.099 : H245 MSC INCOMING PDU ::=
sessionID 1
network 'AC109862'H
tsapIdentifier 24520
network 'AC109862'H
tsapIdentifier 24521
013219: *Jun 20 17:49:49.099 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013220: *Jun 20 17:49:49.099 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013221: *Jun 20 17:49:49.099 : //849/80DD1AF00500/H323/cch323_get_olc_ack_instance: Received OLC_ACK1 msg olc[1] ccb olc[1]
013222: *Jun 20 17:49:49.099 : //849/80DD1AF00500/H323/h245_iwf_request_rsvp_on_olc_ack: ch=1 non-bestEffort=0 sync=0 is_ipip=0, nonsync_rsvp=0
013223: *Jun 20 17:49:49.099 : //849/80DD1AF00500/H323/h245_iwf_request_rsvp_on_olc_ack: qos_mod_used=0, callType=0, do_rsvp=0, flowMode=1
013224: *Jun 20 17:49:49.363 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
013225: *Jun 20 17:49:49.363 : H245 MSC INCOMING ENCODE BUFFER::= 22C000010480101C0200AC108811154500AC1088111546
013226: *Jun 20 17:49:49.363 :
013227: *Jun 20 17:49:49.363 : H245 MSC INCOMING PDU ::=
sessionID 2
network 'AC108811'H
tsapIdentifier 5445
network 'AC108811'H
tsapIdentifier 5446
013228: *Jun 20 17:49:49.363 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013229: *Jun 20 17:49:49.363 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013230: *Jun 20 17:49:49.363 : //849/80DD1AF00500/H323/cch323_get_olc_ack_instance: Received OLC_ACK1 msg olc[2] ccb olc[1]
013231: *Jun 20 17:49:49.363 : //849/80DD1AF00500/H323/h323_open_add_video_rtp_stream: ip_video_tos 136
013232: *Jun 20 17:49:49.363 : //849/80DD1AF00500/H323/h245_iwf_request_rsvp_on_olc_ack: ch=2 non-bestEffort=0 sync=0 is_ipip=0, nonsync_rsvp=0
013233: *Jun 20 17:49:49.363 : //849/80DD1AF00500/H323/h245_iwf_request_rsvp_on_olc_ack: qos_mod_used=0, callType=0, do_rsvp=0, flowMode=1
013234: *Jun 20 17:49:49.363 : //849/80DD1AF00500/H323/estCfmOlcIndoneAwaitEstCfm: Sending olc ack trigger to peer side
013235: *Jun 20 17:49:49.363 : //-1/xxxxxxxxxxxx/H323/cch323_do_open_channel_ack: callID=849, sending event CC_EV_H245_OPEN_CHANNEL_ACK, peer channel pointer 0x3154B22C
013236: *Jun 20 17:49:49.363 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=157, Call Id=849
013237: *Jun 20 17:49:49.363 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
013238: *Jun 20 17:49:49.379 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
013239: *Jun 20 17:49:49.379 : H245 MSC INCOMING ENCODE BUFFER::= 4C000128
013240: *Jun 20 17:49:49.379 :
013241: *Jun 20 17:49:49.379 : H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= command : miscellaneousCommand :
logicalChannelNumber 2
type videoFastUpdatePicture : NULL
013242: *Jun 20 17:49:49.379 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013243: *Jun 20 17:49:49.379 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013244: *Jun 20 17:49:49.379 : //849/80DD1AF00500/H323/cch323_h245_misc_cmd: From h245 to CC, choice: 6, dest_cc: 2A1296F4
013245: *Jun 20 17:49:49.379 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=167, Call Id=849
013246: *Jun 20 17:49:49.379 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
013247: *Jun 20 17:49:49.583 : h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
013248: *Jun 20 17:49:49.583 : H245 MSC INCOMING ENCODE BUFFER::= 4C000128
013249: *Jun 20 17:49:49.583 :
013250: *Jun 20 17:49:49.583 : H245 MSC INCOMING PDU ::=
013251: *Jun 20 17:49:49.587 : h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
013252: *Jun 20 17:49:49.587 : h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
013253: *Jun 20 17:49:49.587 : //849/80DD1AF00500/H323/cch323_h245_misc_cmd: From h245 to CC, choice: 6, dest_cc: 2A1296F4
013254: *Jun 20 17:49:49.587 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
013255: *Jun 20 17:49:49.587 : //849/80DD1AF00500/CCAPI/cc_api_event_indication:
013256: *Jun 20 17:49:49.755 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
Event=167, Call Id=850
013257: *Jun 20 17:49:49.755 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
013258: *Jun 20 17:49:49.755 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=849
013259: *Jun 20 17:49:49.755 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_MISC_CMD: data ptr=0x2A1B7898
013260: *Jun 20 17:49:49.755 : //-1/xxxxxxxxxxxx/H323/cch323_post_misc_cmd_ind: Entry, callID=849
013261: *Jun 20 17:49:49.755 : //849/80DD1AF00500/H323/cch323_get_video_olc_in_channel_num: cch323_get_video_olc_in_channel_num video olc in_lcn 2
013262: *Jun 20 17:49:49.755 : //849/80DD1AF00500/H323/cch323_convert_to_misc_cmd_info: cch323_convert_to_misc_cmd_info converting miscellaneous command Video Fast Update Picture
013263: *Jun 20 17:49:49.755 : H245 MSC OUTGOING PDU ::=
013264: *Jun 20 17:49:49.755 : H245 MSC OUTGOING ENCODE BUFFER::= 4C000128
013265: *Jun 20 17:49:49.759 :
013266: *Jun 20 17:49:49.783 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
013267: *Jun 20 17:49:49.783 : //850/80DD1AF00500/CCAPI/cc_api_event_indication:
013268: *Jun 20 17:49:49.783 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=849
013269: *Jun 20 17:49:49.783 : //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_MISC_CMD: data ptr=0x2A1B7898
013270: *Jun 20 17:49:49.783 : //-1/xxxxxxxxxxxx/H323/cch323_post_misc_cmd_ind: Entry, callID=849
013271: *Jun 20 17:49:49.783 : //849/80DD1AF00500/H323/cch323_get_video_olc_in_channel_num: cch323_get_video_olc_in_channel_num video olc in_lcn 2
013272: *Jun 20 17:49:49.783 : //849/80DD1AF00500/H323/cch323_convert_to_misc_cmd_info: cch323_convert_to_misc_cmd_info converting miscellaneous command Video Fast Update Picture
013273: *Jun 20 17:49:49.783 : H245 MSC OUTGOING PDU ::=
013274: *Jun 20 17:49:49.783 : H245 MSC OUTGOING ENCODE BUFFER::= 4C000128
013275: *Jun 20 17:49:49.783 :
013276: *Jun 20 17:50:33.079 : //850/80DD1AF00500/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x315D253C, Call Id=850
013277: *Jun 20 17:50:33.079 : //850/80DD1AF00500/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
013278: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/ccConferenceDestroy:
Conference Id=0xA6, Tag=0x0
013279: *Jun 20 17:50:33.079 : //849/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
013280: *Jun 20 17:50:33.079 : //850/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=849, Disposition=0x0, Tag=0x0
013281: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/cc_generic_bridge_done:
013282: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
013283: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
013284: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
013285: *Jun 20 17:50:33.079 : //850/80DD1AF00500/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
013286: *Jun 20 17:50:33.079 : //850/80DD1AF00500/CCAPI/ccCallDisconnect:
013287: *Jun 20 17:50:33.079 : //850/80DD1AF00500/CCAPI/cc_api_get_transfer_info:
013288: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/cc_api_get_transfer_info:
013289: *Jun 20 17:50:33.079 : H225.0 OUTGOING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling FALSE
013290: *Jun 20 17:50:33.079 : H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110080DD1AF0F04DF1DF0500AD01AC10986210800100
013291: *Jun 20 17:50:33.079 :
013292: *Jun 20 17:50:33.079 : //849/80DD1AF00500/H323/cch323_h245_connection_sm: state=0, event=4, ccb=29EEFA44, listen state=2
013293: *Jun 20 17:50:33.079 : //849/80DD1AF00500/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30C4D994, Tag=0x0, Call Id=849,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
013294: *Jun 20 17:50:33.083 : //849/80DD1AF00500/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
013295: *Jun 20 17:50:33.083 : //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
013296: *Jun 20 17:50:33.083 : :cc_free_feature_vsa freeing 2A008F70
013297: *Jun 20 17:50:33.083 : //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
013298: *Jun 20 17:50:33.083 : vsacount in free is 1
013299: *Jun 20 17:50:33.083 : //850/80DD1AF00500/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x315D253C, Call Id=850
013300: *Jun 20 17:50:33.083 : //850/80DD1AF00500/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x315D253C, Tag=0x0, Call Id=850,
013301: *Jun 20 17:50:33.083 : //850/80DD1AF00500/CCAPI/cc_api_call_disconnect_done:
013302: *Jun 20 17:50:33.083 : //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
013303: *Jun 20 17:50:33.083 : :cc_free_feature_vsa freeing 2A008E90
013304: *Jun 20 17:50:33.083 : //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
013305: *Jun 20 17:50:33.083 : vsacount in free is 0
06-27-2011 09:41 AM
what are endpoints are you using for video ?
06-28-2011 06:20 AM
From CUCM side is Cisco IP Phone 7975 (sccp75.8-5-4s) with MS Lifecam Cinema , from CME side i tried diffrent models with same result: 7961, 7941, CIPC 7.0.6.0
