Video chat using Jabber Guest in UCCX Enviroment
Hi Guys
I'm facing a difficulty determining & planning a topology to implement a Video chat/call from a web page  to an Call center agent . Cisco has 2 product in UCCX 10.X :
- Cisco Remote Expert with Video Care
- Cisco Jabber Guest ( with Expressway)
Do any one have experience implementing or sizing this solution, Cisco licensing & call flow is not really clear in this issue . Your help is highly appreciated .
Best Regards
Ahmed Abd El-Baky
Manish Gogna
Hi Ahmed,
The Deployment and config guide for Jabber Guest will answer most of your queries
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_0/icg/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide_chapter_01.html
Manish
Hi Manish
Many thanks for your reply , Yes the Jabber Guest & Expressway configuration is defined in detail in the guide but not the video feature availability & design considerations . If you could provide an answer or a document to that issue it will be really appreciated.
Also The software version (JabberGuest10.5.3.115-New-Install.iso) is not found on Cisco.com , just the update ISO
Ahmed
Hi Ahmed,
you could probably be interested in 3rd party video chat solution that integrates with UCCX/UCCE, please check - http://aurus5.com/richcall
