Video OSD EncryptionIndicator command in sw TC5.X
mguguvcevski
As you are aware, there is a possibility to disable the OSD EncryptionIndicator little lock icon od the right lower part of the TP screens with sw TC 6.0.
I was wondering is there a tsh or root command to do the same in TC 5.X ?
Thanks!
Mihail
amehla
Hi Mihail,
the OSD encryption indicator setting is introduced in TC 6, you will not able able to find this setting in TC 5 software version.
to enable to from SSH in TC 6 , you can use below command:
xconfiguration video OSD encyptionindicator : auto/alwaysoff/alwayson
