Videoconferencing Test IP/SIP addresses?
External.Jabber
Hi all
Does anyone have any test IP/SIP addresses they use?
We used to have a bunch we connected to with live camera feeds in various cities (japan, new york, bandipur, denver), and one with a cool fishtank, but the IP address no longer seem to be active. We often use them to show clients examples of international connection quality over IP from our codecs.
Only active one with a live camera I can find now is this one in Hong Kong - 202.83.223.195
Anyone know of any? :)
Cheers
edit- sorry if I posted this in the wrong area. Not clear on forum categories just yet.
19 Replies 19
Jens Didriksen
Level 9
Level 9
You might find some on this list which are still working - haven't checked it in quite a while so don't know how up to date it is: http://www.thefreerangetechnologist.com/?page_id=2282
The fishtank you mentioned is most probably the LifeSize site, think the address was fishtank.lifesize.com, but not too sure.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Yeah, that's the site I got a bunch of them from years ago, but most of them seem to not be active anymore, including the fishtank.
Thanks though!
That's the site I've used in the past too.  A few others I use are:
  • Parrot at BlueJeans: 111@199.48.152.152
  • Cisco TAC Loopback: loopback@rtp.ciscotac.net
  • CSIRO Test: 0262463194@csiro.au
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
hi Wayne,
I'm receiving "Moved Temporarily" in my Expressways when call to loopback@rtp.ciscotac.net. is it okay and working?
BTW, CSIRO is working fine
Hi Ruslan,
I see the same in the vcs log, they redirect you into a new conference which is
then just echoing your video back. So it is okay and for me its working fine.
When you dial in, do you get connected or not, you must be the one who knows / sees if its working or not :-)
If its not working for you, you might want to check why.
hi Martin,
yeah, I suppose it must work. I had VCS-C,E deployed, I can succesfully call loopback@rtp.ciscotac.net and then those services must be deployed in hurry on Expressway-C,E platform. And then it happened that I can't call to this loopback.
I think it's improbable that I was mistaken in configuration because I can call to CSIRO and some another conferencing room at Cisco, but still.
do you have VCS or Expressway infrastructure deployed?
I was connected to a VCS-E cluster.
Works fine for me; VCS-C -->VCS-E
/jens
I see.. it seems to me that something works not as it might expected..
could someone provide me with this redirected address? I want to test it too.
Did you try any of the other addresses listed?
Wayne
I tried CSIRO Test: 0262463194@csiro.au mentioned by you and another one conferencing room at Cisco, they are work just fine
Hi Ruslan,
You can test videocall with me ). I sent my video address in e-mail.
br Oleksandr
thanks!
I'll call you soon:).
hi guys,
I've solved this issue already, CSS for Rerouting parameter in the SIP trunk (CUCM side) was incorrectly configured.
now after Moved Temporarily call is redirected and connected to another room.
