I succeeded to use Video over IP between a CCME 4.0 and a CCM6.0.
I'm using the H323 protocol with codec g711u.
There are the success and problems :
1.From a IPCommunicator registered with the CCME to an IPCommunicator registered with the CCM6.0
the voice and the Video pass.It's the same case from CCM6.0 to CCME4.0
3.From a IPCommunicator registered with the CCME to an IPPhone registered with the CCM6.0
the voice and the Video pass. It's the same case from CCM6.0 to CCME4.0
The problem is that :
3.From a IPPhone registered with the CCME to an IPPHone registered with the CCM6.0
the voice pass but the Video doesn't.
3.From a IPPhone registered with the CCME to an IPCommunicator registered with the CCM6.0
Question :
I think that there is a mismatch arround the RTP connection.
i.e The video rtp stops in the phone and don't go to the PC where the video should be ended with the VTadvantage.
So what can be the error?
Is there any workaround?
