10-25-2012 09:14 AM - edited 03-18-2019 12:02 AM
Hello All,
I see that the TP Condcutor has VM Option but what i couldn't find it what hardware it is supported on? Is this supported on UCS only or can we install this on a spec based scenerio.
I tried to find a Doc Wiki or some documentation but couldn't see to find anything. If anyone has a link could you please share.
Thanks in advance,
CJ
Solved! Go to Solution.
10-25-2012 09:24 AM
Hi Joseph,
check the below link.
Recommended platform
The recommended hardware on which to run a TelePresence Conductor VM is:
n Cisco UCS C200 – M2, UCS C210 – M2, or UCS B200 – M2 with:
l Processor supporting AESNI feature
l 6GB of RAM per VM
l 132GB disc space per VM (for a 4GB virtual disc 1 and a 128GB virtual disc 2)
l R2XX-LBBU (Raid disk battery backup to enable cache)
l Four hard disks (450GB SAS 15K RPM 3.5in HDD/hot plug/C200 drive sled)
l PCI card Intel Quad port GbE Controller (E1G44ETG1P20)
rgds
Alok
10-25-2012 09:24 AM
Hi Joseph,
l 6GB of RAM per VM
rgds
Alok
10-25-2012 09:46 AM
thanks - I was looking through the release notes - didn't think to look here.
CJ
01-09-2014 01:20 AM
from where can i download the VM image for TP conductor to install on machine.
01-09-2014 10:36 AM
