09-25-2023 10:36 PM
Hi Guys..
Can anyone help here to address the below queries?
** Is there any other options or solution available to join a Google Meet from a On-Prem CUCM registered Room Kit device apart from WebRTC join with device cloud on-boarding using Webex edge for devices or USB Passthrough option for 3rd party meetings?
** Can we enable zoomcrc SIP URI dialing on a On-Prem registered Room Kit device to join a scheduled Zoom Meeting using Macros?
Kindly share if you have any documents or leads to achieve above scenarios.
Thanks in advance!!
09-26-2023 12:55 AM
check my solution to enable joining MS Teams by using WebRTC at on-prem registered devices, you can use the similar way to enable google meet so you can join by using meeting ID ,
pleas mark with helpful if it is acceptable solution
09-26-2023 07:06 AM
Thanks for your information.
09-26-2023 03:04 AM
As for Zoom: sure but the SIP call will need to traverse CUCM/Expressway. If the endpoint is running RoomOs 11 you should be able to toggle the built-in Zoom button - same as Google. If 10 or earlier you can use the Join Zoom and Zoom Tools macro.
09-26-2023 03:29 AM
Thanks for your reply.
The endpoint (Cisco Webex Room Kit) is running RoomOs 11 latest suggested release but still unable to find the built-in Zoom and Google Meet button in room navigator. Is this available only in cloud registered RoomOs 11 endpoints or available in endpoints running RoomOs 11 irrespective of registration?
09-26-2023 03:35 AM
No, it is not limited to cloud-reg or cloud-aware. You will need to enable those features from the admin web UI or CLI.
09-26-2023 03:39 AM - edited 09-26-2023 04:30 AM
Ok..
Have managed to find those options from web UI and enabled JoinZoom and it's working but JoinGoogleMeet option is only available when device is cloud-reg or cloud-aware, it is clearly mentioned over there in info part.
09-26-2023 10:01 AM
Ah, you're right - the documentation for xConfiguration UserInterface Features Call JoinGoogleMeet does state that. Nice catch.
