Webex Room Kit - Meeting platforms joining options
Santhosh738
Hi Guys..
Can anyone help here to address the below queries?
** Is there any other options or solution available to join a Google Meet from a On-Prem CUCM registered Room Kit device apart from WebRTC join with device cloud on-boarding using Webex edge for devices or USB Passthrough option for 3rd party meetings?
** Can we enable zoomcrc SIP URI dialing on a On-Prem registered Room Kit device to join a scheduled Zoom Meeting using Macros?
Kindly share if you have any documents or leads to achieve above scenarios.
Thanks in advance!!
7 Replies 7
check my solution to enable joining MS Teams by using WebRTC at on-prem registered devices, you can use the similar way to enable google meet so you can join by using meeting ID ,
pleas mark with helpful if it is acceptable solution
https://community.cisco.com/t5/unified-communications-infrastructure/onprem-webrtc-with-deskpro-roomkit/m-p/4552164#M170138
Thanks for your information.
Jonathan Schulenberg
As for Zoom: sure but the SIP call will need to traverse CUCM/Expressway. If the endpoint is running RoomOs 11 you should be able to toggle the built-in Zoom button - same as Google. If 10 or earlier you can use the Join Zoom and Zoom Tools macro.
Thanks for your reply.
The endpoint (Cisco Webex Room Kit) is running RoomOs 11 latest suggested release but still unable to find the built-in Zoom and Google Meet button in room navigator. Is this available only in cloud registered RoomOs 11 endpoints or available in endpoints running RoomOs 11 irrespective of registration?
No, it is not limited to cloud-reg or cloud-aware. You will need to enable those features from the admin web UI or CLI.
Ok..
Have managed to find those options from web UI and enabled JoinZoom and it's working but JoinGoogleMeet option is only available when device is cloud-reg or cloud-aware, it is clearly mentioned over there in info part.
Ah, you're right - the documentation for xConfiguration UserInterface Features Call JoinGoogleMeet does state that. Nice catch.
