WebEx Room Kit Plus
I have a site that recently installed a Room Kit Plus, the datasheet indicates that it comes with integrated microphone, but the it doesn't work. Is there a configuration that needs to be done?
JFerello
The WRK Plus, via the Quad Camera does not have an integrated MIC. Only the plain Room Kit has an integrated MIC.
Justin Ferello
Matt_W
Level 3
Level 3
The mic built into the room kit plus is strictly for speaker tracking and not for audio pickup.  for that you will need to put in the table or ceiling microphones.
(6-element microphone array for accurate speaker tracking)
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spark-room-kit-series/datasheet-c78-738752.html
Wayne DeNardi
You possibly missed the little star on the data sheet where it says integrated speakers and microphones *
At the bottom of the data sheet, the * is expanded as:
* Integrated microphones for speaker tracking only
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
