Webkit Pro with Quad cam makes intermittent tick, tick, tick, tick noise
ScottWitt26145
It seems like it sending out a audio sound to detect something.  It does it mostly when starting up the system, but have been getting reports that it will do it intermittently.
Any ideas?
Thanks!
Scott
Wayne DeNardi
It's likely the Proximity Ultrasound - if you have an external audio system connected to your device, these can often make the ticking sound worse.   You should either use some external DSP to strip out the ultrasound from your external speakers, or, if you don't need to use it, disable the proximity feature and it'll get rid of the noise.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
