cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
What is the recommended TV Screen Size for Room Kit Plus and Pro?
WeiKwongOng5555
Thank you.
5 RESPOSTAS 5
Ashish Patel
Hi Ashish, I am not able to find the recommended TV Screen Size from the best practice. Do you mind to tell which page you are referring to?
Thank you.
TV size is defined not by Cisco codec. it would be selected based on the conference room.
I have used 55, 65,&75 and 55 Dual etc.. with CS kit series.
Response Signature
As Nithin Eluvathingal says really depends on room size and height and placement or camera, type of camera, hence no recommendation but guidance in that document.
Response Signature
Project work space give u recommendations regarding the product to be used based on the number of participants. but the size of the TV depends on your room size. if your room is too  small you cannot use a 65"  75" or 85" TV. if you are planning to hang the TV on wall u need to consider the strength of the wall etc...
Response Signature
