Where does C60 log the IP of a calling party?
Mateusz Starzak
I can't seem to find anywhere in the logs the IP address of the person calling my vc endpoint. xHistory shows only the e164 alias, and in text logs the same, along with the IP address of H323 gatekeeper I'm registered with. Unless there's some secret handshake or SIP-like "reinvite" initiated by my C60 that forces the caller's terminal to reconnect using the gatekeeper (which I'm not aware of) the call is a direct IP connection. Could anyone point me to the right direction?
Martin Koch
It depends on your infrastructure if you use h323, if you use a VCS the signaling will
always be handled via the VCS only media might be send directly in between endpoints.
Not sure if the media ip is logged somewhere on the endpoint, but you should find that out
when you are in the call, but that can also be the gk if assent / h.460.18 is used.
The right to place to look at would be the call control / gk / vcs / ...
