04-10-2017 02:00 AM - edited 03-18-2019 12:59 PM
Recently have purchased few unit of SX2oN and can't find how the preset can be SET and Recall with TRC6 remote, anyone can assist? because during POC SX20 with TRC5 remote was used and also being told that no different between this two model. And camera preset is a must features. No touch control in this setup.
Solved! Go to Solution.
04-21-2017 10:27 AM
Additional camera presets beyond the default would need to be activated using the web interface or API.
It's the simplified user interface of CE software that is preventing the creation of presets using the remote control, simply because the UI doesn't include an option to.
04-10-2017 04:47 PM
As [@patrick.sparkman] mentioned, there is no way to set or trigger multiple camera presets using a TRC with CE software on the endpoint like you could with TC. The only ways are using the web interface, or a Touch 10. I've asked our local account team to ask that this is logged as a feature request to be added back in, and I'd suggest that anyone else who needs this functionality also raise their voice through their local account team.
You can however change the default camera location preset using the TRC and CE through the settings menu.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-12-2017 09:39 PM
The unofficial response from the developers is along the lines of: no for any remote development currently, the new hardware does not support TRC, the focus is on the Touch interface. So I suspect that the remote will be something that will become a thing of the past in the not too distant future.
Wayne
09-21-2017 07:38 AM
I read all of you're post and having trouble using the CLI with the 9.1 API reference guide on a SX20 new codec
when i send
xCommand UserInterface OSD Key Click Key: SrcPc
or these other one
/Selfview/Square/SrcAux/SrcCamera/ SrcDocCam/SrcPc/SrcVcr/
The OSD tell me that it's not avalaible and i need to used the more recent TRC6 remote.
Any clue ?
I need to be able to choose the SrcPC or SrcCAM / selfview by script.
Thank you :)
09-21-2017 08:01 AM
09-21-2017 08:12 AM
Thank you
i found a xCommand Presentation start/stop that do the job well.
Thank you :)
09-21-2017 01:52 PM
To set the main video source for the camera:
xCommand Video Input SetMainVideoSource ConnectorId
To set the presentation video source:
xCommand Presentation Start ConnectorId
To find the connector ID:
xStatus Video Input Connector
The connector ID is also printed on the codec connector panel.
