Can CMS replace Jabber Guest as WebRTC Solution?
mesut ozcan
Dear all,
One of my customer wants to deploy a WebRTC solution. This solution should be used by external participants without requiring a client to join internal conferences. My advice was to deploy Jabber Guest.
What is your opinion? Should I proceed with CMS or is Jabber Guest still an acceptable solution for clientless WebRTC requirements?
Thanks in advance,
Mesut
Jonathan Schulenberg
Jabber Guest isn’t clientless - it requires a browser plugin. If you want true WebRTC then look at CMS or CafeX.
How can i go further with CMS?
Do you have deep knowledge about it?
Mesut
