cisco cms MMP problem
shu shen
i have a cms in lab environment. cms has deployed in third party server.  i found that i can't response the prompt command.
example:
i input shutdown  then  i can't input confirmed by  "yes". the server looks like hang.
i input  database cluster initialize ,same questions, can not input "yes"
Jaime Valencia
Take a close look at the options from the prompt, they're not yes or no, they're Y or n. Either you enter capital y (Y) or you enter lowercase n.
java
if this helps, please rate
Jaime Valencia
java
Hi  Jaime Valencia
Thank you very much for your reply, my negligence. I ignored uppercase and lowercase.
