07-08-2017 11:34 AM - edited 03-18-2019 01:16 PM
I have install core,edge and database and need to configure it can any one help me in this regard
07-10-2017 05:28 PM
From the design point of view you can use Expressway-E as for turn server and web proxy.
in addition to link given by Patrick, also look at the below document, for using expressway for web proxy with CMS.
http://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/210800-Configure-CMS-WebRTC-Proxy-over-Expressw.html
So CMS Core will be seating inside your LAN and will be utilizing expressway for proxy.
Alok
07-11-2017 01:32 AM
Hi Both,
I have gone through the guide but its not much helpful in configuration especially if i am new and its my first deployment.So is there any other way to do it??
07-11-2017 05:59 AM
Didn't you review the Collab 250 material???
https://supportforums.cisco.com/discussion/13307616/cisco-meeting-server-installation-help-needed
Doesn't cover S4B or EXP-E, but it does cover all the components in core that you need.
