04-18-2016 10:49 PM - edited 03-18-2019 05:49 AM
I noted on a couple systems I uploaded TC7.3.5 via WEB Remote that they get hung on the last part of the upgrade I.e.
At the point it states System installs hooks etc.
I have to restart the system and it reverts to the old firmware which makes sense.
Why would it be handing up on the last part of the install processes ...
thanks.
Solved! Go to Solution.
04-19-2016 05:51 PM
Hi Chet,
As I mentioned in the other thread where you first mentioned this, there is usually some software or hardware issue that causes this. You can try doing a factory reset on the device then try upgrading again. If this still doesn't help, it's likely you have faulty equipment and you should organize an RMA through the TAC.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
05-10-2016 12:00 AM
Hi Chet,
A few days ago I had a similar issue upgrading C40, C60, and C90 from version 6.2.0, and MX300 G2 from version 7.3.0 (if I remember correctly) to version 7.3.6
The upgrade was always stuck in “Running post-install hooks from installed package” stage, doesn't matter if I'm using TMS v14.2.1 or via web interface.
The workaround was to upgrade/downgrade to version TC7.1.1, and then upgrade to TC7.3.6, I used TMS to push both images.
HTH,
Mazen
04-19-2016 12:59 AM
I never tried upgrading C60 . But u are trying to upgrade C60 from which version since e have faced issue sometimes while upgrading C20 and C40/EX60
regds,
aman
04-19-2016 01:38 AM
One system I tried with a valid upgrade to TC7.3.5 from TC6.2.1 and the other one is TC7.3.3 to TC7.3.5 ...
04-19-2016 02:33 AM
Did u verify the checksum of TC7.3.5 before uploading?
regds,
aman
05-10-2016 12:00 AM
Hi Chet,
HTH,
Mazen
04-19-2016 07:25 AM
Try the upgrade again, only this time open a telnet or ssh session to the codec prior to starting the upgrade. You can monitor the upgrade progress through the CLI, and often the CLI will give you more information than the web interface when an upgrade fails.
04-19-2016 05:51 PM
Hi Chet,
Wayne
04-19-2016 08:04 PM
Yes I was thinking that also. Thank you.
12-01-2016 09:50 AM
I had the same issue and the step-upgrade worked for me. Thanks.
