VCS-E migration issue
bradatbcass
Hi, we have a virtualized VCS-E which I attempted to migrate to a new host. I ran into issues and found several articles saying that new license keys needed to be purchased for a migration, but they referenced migrating off a physical server to virtual. I am simply trying to clone the virtual instance and migrate to a new physical host.
Before I open a TAC case, does anyone know if it is necessary to purchase new licensing for this type of migration?
Brad
Anurag Srivastava1
Spoiler
No you need not need to purchase new licenses.
Just need to transfer your licenses from old to new serial number.
also if you are migrating on same version you can take backup from old server and upload on new one.
The only thing needed is for new serial number you need to transfer your release keys and option keys, that you can try doing with licensing portal or opening a case with Cisco licensing tea,
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
Anurag Srivastava1
Spoiler
