01-29-2016 06:46 AM - edited 03-18-2019 05:30 AM
We are using a Cisco CUCM and IM&Presence system across three sites over MPLS for voice only. Lately, we are looking for internal Multi-Party Video Conference solution across these three locations using SX20, SX10 and Jabber for mobile.
Can I make a video conference with current equipments (CUCM and IM&Presence) or t is there are another bridge that I have to add ? Thanks
Solved! Go to Solution.
01-29-2016 08:59 AM
Yes, you can register a vTP to CUCM as a CFB.
01-29-2016 07:58 AM
I suggest you review this, page 18
http://www.cisco.com/c/dam/en/us/td/docs/solutions/PA/midmarket/11x/video11x.pdf
01-29-2016 08:35 AM
thaks Jaime for the suggestion. but what I want to know is with only 3 sites(one sx10, one sx20 and one jabber for mobile) can i only use CUCM with conference bridge without the TMS and Conductor ?
01-29-2016 08:59 AM
01-29-2016 09:23 AM
can you explain more about vTP and CFB ?
01-29-2016 10:57 AM
You'll register the vTP to CUCM as a CFB, are you familiar with Cisco UC??
If not, perhaps you should be reaching out to a Cisco partner who can provide advice of what would work best on your particular environment to fulfill your needs for video conferencing.
01-30-2016 12:08 PM
yes im familiar with CUCM but I have not set before the CFB so i have one last question for clarification
For example:
I'll register an SX20 on CUCM to use it for video conference:
So is what I'm going to Register the SX20 as a device: device / phone / add new / SX20 ...
or
i must go directly to media resources / conference bridge / add new / choose the type of CFB /MAC address of the SX20...
01-31-2016 06:54 PM
The SX20 is an endpoint, not sure under what reasoning, you would try to add it as a CFB
If you're not familiar with media resources, which is something every single deployment I've ever seen uses, you probably want to read the media resources chapter from the system guide, and also the same chapter from the SRND.
02-01-2016 01:16 AM
OK thanks Jaime for your help :) i'll try to register vTelepresence Server with CUCM as CFB and SX20, SX10, Jabber for mobile as endpoints.
