WebEx Codec Plus
Can one extend the antenna on the Codec Pro?I ask because I have a site that is installing the codec with a projector and the codec will be located at their sound room.
PJMack
Level 7
Level 7
The sound room - it has wired network connections, does it not? If so, why would you use wifi? From my experience I would use wired ethernet whenever possible, it's just likely to be more reliable. It would make more sense to run a wired connection than to try to extend the antennas to a different area for connectivity.
