12-17-2014 09:09 AM - edited 03-18-2019 03:48 AM
Hi there,
I want to make a demo with one MX300 G2 and MX200 G2 for a customer.
I want to use both endpoints in a standalone mode, the customer doesn't have any vcs or cucm. ( Point to point call);
I read in the following thread that i must use H323 to be able to make calls directly:
https://supportforums.cisco.com/discussion/12340271/cisco-mx300-tcs-standalone
Here are the settings for both devices:
IP address: 192.168.1.229
mask : /24
default GW: 192.168.1.250
h323 mode: Direct
H323 Alias E164 : 2003
H323 Alias ID: youssef.aoufi@company.com
Default call protocol: H323
IP address: 192.168.1.230
mask : /24
h323 mode: Direct
H323 Alias E164 : 2004
H323 Alias ID: user.test@company.com
The main problem is that i don't know how to dial :
if i dial 2004 from the MX300 i receive the following message: cannot connect call
If i dial: user.test@company.com from the MX300 i receive the following message: cannot connect call
If i dial: 192.168.1.230 from the MX300 i receive the following message: cannot connect call
If i dial: 2004@192.168.1.230 from the MX300 i receive the following message: could not place call to sip:2004@192.168.1.230.
I think i am missing something.
Thank you in advance for your help
12-17-2014 10:07 AM
Hi there,
Issue resolved, The H323 mode was disabled on the MX300.
12-18-2014 12:38 AM
good luck, are you planning to deploy vcs or cucm as call control ?
regards
Anas
12-18-2014 02:43 AM
Hi Anas,
Thank you :) We will deploy it in standalone mode waiting for the arrival of the CUCM.
