2951 Running CME Random Reload
jejarosz1
Hi all, I have a 2951 that randomly reloaded this morning. The crash file is attached. I took out the phone numbers called at the beginning of the file for security.
The 2951 has 512M of memory, the following line is in the crash file.
09:36:05 CDT Mon Jun 11 2018: Unexpected exception to CPU: vector 1400, PC = 0x86638AC , LR = 0x85B4750
Could this be a memory related issue, or any other thoughts?
5 Replies 5
Ratheesh Kumar
Hi there
Can you share the show version and Dir (router#dir). You might be able to see the crashinfo files in flash. Send that over.
Could be DRAM issue. lack of memory
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
The crash info file was attached to the 1st post, but I'm attaching it again here.
also here is the show version
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 17:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
PBX_System uptime is 6 hours, 26 minutes
System returned to ROM by address error at PC 0x86638AC, address 0x908300B4 at 17:10:39 CDT Wed Jun 6 2018
System restarted at 09:37:49 CDT Mon Jun 11 2018
System image file is "flash0:c2951-universalk9-mz.SPA.151-4.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 483328K/40960K bytes of memory.
Processor board ID FTX1615AKJ0
3 Gigabit Ethernet interfaces
24 Serial interfaces
1 terminal line
2 Channelized T1/PRI ports
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
507024K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FTX1615AKJ0
Technology Package License Information for Module:'c2951'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          datak9        Permanent      datak9
Hi there
Whats the free space in your router#dir
router#dir
Hope this helps!
Cheers
Rath!
518750208 bytes total (408485888 bytes free)
I just found some additional information from the show tech-support command, does this help at all?
System was restarted by address error at PC 0x86638AC, address 0x908300B4 at 17:10:39 CDT Wed Jun 6 2018
Compiled Tue 06-Dec-11 17:34 by prod_rel_team (current version)
Image text-base: 0x040001B0, data-base: 0x0C000000
Stack trace from system failure:
FP: 0x19765D08, RA: 0x86638AC
FP: 0x19765D18, RA: 0x85B4750
FP: 0x19765D40, RA: 0x85B4CFC
FP: 0x19765D70, RA: 0x858E48C
FP: 0x19765D98, RA: 0x85BF0FC
FP: 0x19765DB0, RA: 0x850F440
FP: 0x19765DC8, RA: 0x850E858
FP: 0x19765DF8, RA: 0x850E90C
