ā04-25-2011 10:18 AM - edited ā03-19-2019 02:49 AM
I'm planning a CMBE upgrade from 7.X to 8.5 for a customer without UCSS using 3X3 upgrade. The part numbers that I'm using are UPG-BE5K-ENH, UPG-BE5K-VMB2A, UCSS-BE-KENH-3-1 and UCSS-BE-KVMA-3-1. I assume these are the correct part numbers. What I am having problems with is finding the ESW part numbers for this upgrade.
ā04-25-2011 10:35 AM
The ESW is CON-ESW-UPBE5KEN (10 list) and CON-ESW-UBE5KV2B (8 list)
Srini
ā04-25-2011 10:39 AM
Does that also include the hardware smartnet on the 7828-H3 server or is there a separate CON-SNT part number for that now.
Pre 8.X I believe the server was included in the ECPM Smartnet number.
Thanks again for your help,
Steve
ā04-25-2011 10:46 AM
Depending on the server you pick you will see maintenance SKU. For the MCS7828I5-K9-BE8B, you will CON-SNT-MCS7888I assuming 8X5XNBD.Likewise there are other levels. DCT should be able to help you here
Srini
