4331 CUE - Not active after 4331 upgrade from 16.9.5 to 17.9.4a
keanej
Level 3
Level 3
Folks
We have upgraded our 4331 from version  16.9.5 to 17.9.4a
Everything is working - however we are running a CUE application and now that module wont activate.
% Error: Virtual service cue is not activated
XXXX-4331-VoIP(config-virt-serv)#activate
% Feature License request fails
This was purchased will all the required licensing - so im a little confused.
What feature request is required? How do I enable it ?
Any help appreciated
James
Carlo
Thanks for taking an interest, and taking the time to investigate.
It turns out this is a bug.. or compatiablty issue.
Basically the CUE Application needs to be upgraded to 10.2.1 or above to activate with IOS version 17.
So if your on 10.2.0 or below - you can only use IOS version 16 on the router
If you migrate to 10.2.1 or 10.2.2 - you can use IOS version 17 on the router.
Some people might be reluctant to do this as cisco no longer allow new mailbox licensing on 10.2.2 - so if you upgrade you cant even buy the licenses, if your lucky enough to own the licenses already, they will be continued to be supported... for now, but you'll have this nagging doubt - will cisco turn it off ? The beauty of the glorious smart licensing.
If you are using the CUE application - you really need to get off it - look at alternate products
End-of-Sale and End-of-Life Announcement for the Cisco Unity Express Version 10.x - Cisco
Thanks again - great to have it sorted
James
https://bst.cisco.com/bugsearch/bug/CSCvy29719
5 Replies 5
From 16.10 IOS  release, smart license is used by default so you need to check if your Router can communicate with CSSM (Cisco Smart Software Manager) on cloud.
The UC_VCUE should be the license PID.
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
keanej
Level 3
Level 3
Are you sure ??
I can see the license usage - it doesn't say im not in compliance
And I can not find any option to enable - UC_VCUE
How do we enable it ? We have an EA Agreement with the 'fill your boots' type deal.
sho license summary
Account Information:
Smart Account: <none>
Virtual Account: <none>
License Usage:
License Entitlement Tag Count Status
hseck9-ALT (ISR_4331_Hsec) 1 IN USE
appxk9 (ISR_4331_Application) 1 IN USE
uck9 (ISR_4331_UnifiedCommun...) 1 IN USE
securityk9 (ISR_4331_Security) 1 IN USE
SRST_EP (SRST_EP) 20 IN USE
Is it ok to use the Application CUE on IOS version 17 ?
Anyone using it ok?
James
Hi ,
Yes.
please post the output of:
show license usage
show virtual-service list
Show run
Thanks a lot
Carlo
keanej
Level 3
Level 3
Carlo
show license usage
License Authorization:
Status: Not Applicable
hseck9-ALT (ISR_4331_Hsec):
Description: hseck9
Count: 1
Version: 1.0
Status: IN USE
Export status: RESTRICTED - ALLOWED
Feature Name: hseck9-ALT
Feature Description: hseck9
Enforcement type: EXPORT RESTRICTED
License type: Export
appxk9 (ISR_4331_Application):
Description: appxk9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: appxk9
Feature Description: appxk9
Enforcement type: NOT ENFORCED
License type: Perpetual
uck9 (ISR_4331_UnifiedCommunication):
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Feature Name: uck9
Feature Description: uck9
securityk9 (ISR_4331_Security):
Description: securityk9
Count: 1
Version: 1.0
Status: IN USE
Feature Name: securityk9
Feature Description: securityk9
SRST_EP (SRST_EP):
Description: SRST_EP
Count: 20
Version: 1.0
Status: IN USE
Feature Name: SRST_EP
Feature Description: SRST_EP
sho virtual-service list
Virtual Service List:
Name Status Package Name
cue Installed CUE-Virtual-9-0-3-ISR4K.ova
Carlo
James
