09-22-2004 11:48 AM - edited 03-18-2019 03:35 PM
I plan on upgradding a 3.1.5 voicemail only with exchange 5.5 to a 4.0.4 with exchange 2003. Since the initial integration was voicemail only i'm concerned on how to get the messages over to the 2003 exchange after the upgrade, especially if it is a different domain. Is there any documentation concerning this?
09-22-2004 01:07 PM
so I take it the 4.0(4) system with be UM with existing mail accounts that are already in place, right? if that's the case, this can get tricky. If the mail alias (mailnickname) value in the new system match the aliases you used in the 5.5 system, this should work - however that's rarely the case.
Check out this white paper:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/whitpapr/migvm_um.htm
It was written against 3.1 however the prep stuff still applies in the same way here.
09-22-2004 01:23 PM
Thanks for the white paper.
i just want to verify the procedure for upgrading the system.
1. Dirt the 3.1.5 system that is configured with exchange 5.5
2. Wipe the server clean
3. re install the OS and Unity to 3.1.5 with the voicemail only license and now pointing to the new exchange 2003 domain
4. Use Dirt to put the original config back on the new system
5. Install the new license for UM
Could you verify this procedure. i feel like i'm missing something here
09-22-2004 02:45 PM
No, Unity 3.1(5) cannot connect to an Exchange 2003 - you'll need to upgrade the 3.1(5) system to 4.0(4) first, then DiRt it then import it onto the new Exchange 2003 system.
If there are accounts that have different mail aliases, those users are created as new users - just be aware of this. You'll want to carefully review the alias rules you've used on both systems so you know what to expect. Be sure to check out the migration and upgrade guide:
it talks about some of the details of using DiRt. You can also check out the help file and training video on the DiRT home page which can be usefull:
http://www.ciscounitytools.com/App_DisasterRecoveryTools.htm
