AA Script question.
elink
AA Script question:
I have create a custom AA sscript using the GUI.  I am on 8.0.2 of CUE.
I am trying to have a call from the AA transfer to 1 ext and if that ext is not answered, i need the call to transfer to a second ext.
How do I download CUE editor if I have a login but it says I need authorization
Thanks for your help.
gomganes
To download CUE editor from CCO page , you should have CCO account.
You can refer this url for any download issue “Registeration and service contract” http://www.cisco.com/web/Downloads/SDS/Software_Downloads/help.html <http://www.cisco.com/web/Downloads/SDS/Software_Downloads/help.html> .
Gomahthy
Sent: Monday, April 23, 2012 3:01 AM
To: Gomahthy Ganesan -X (gomganes - WIPRO at Cisco)
Subject: - AA Script question.
Cisco Communities <https://communities.cisco.com/index.jspa>
AA Script question.
created by elink <https://communities.cisco.com/people/elink> in Unified Communications - View the full discussion <https://communities.cisco.com/message/91017#91017>
Warren Chang
Hi Elink,
              Within the script it is probably using a Call Redirect step to transfer the call so it should have a few legs below for Busy, Invalid and Unsuccessful you should be able to use the Busy and Unsucessful to add another call redirect here or to transfer the call to the second extension. Just be aware though if the phone your transfering to is set to forward calls to voicemail after you might need to create a hunt group with a shorter reversion time than the voicemail tomeout in that case simply change the extension to the hunt group pilot number and you should be all set.
